BUILDING A UF-1405 ZOOMIE BEST OPTION FOR DRIVER AND LED FOR MAINLY DISTANCE
I hope I’m posting this in the correct location as it’s my first actual post of substance if not I apologize.
I’m planning on making this a Christmas gift for a friend that finally moved on top of a mountain here in East Tennessee. I’ve read a lot but I don’t feel comfortable making the final selection because the insane amount of variables. It hosts 17mm Driver and 16mm MCPCB but I’m flexible and also have access to a metal lathe but I prefer not to get too crazy with it but I can if it supports some crazy results. Yes I’m sure you probably think I’m nuts working on Christmas in September but I also have stage 4 cancer so things don’t go as fast as they use to. Grateful for any responses I get and I don’t hold anyone responsible for their thoughts and ideas if they don’t work out. I learn more when they don’t work out but that doesn’t I don’t them to. Thanks
Groovy. What a great gift idea for a mountaintop dweller! If you’re looking for distance, get an Osram W1 culnm1 LED Drive it to 5 amps with this Driver
OR, for more output but a little less throw, use this driver A17 and this LED
You could go with a sft40 instead of that one also. Use a 10 amp battery for those latter two LEDs.
Your awesome and thank you for the response :smiley: I might actually try both of them with the possibility of using the setup that I don’t use in the smaller UF-1504 Zoomie. Thanks again and if you do anymore brain storming let me know I do appreciate the help
I like the SFT40 emitter.
The SFT40 throws pretty well, and there can be a decent amount of spill if you have the right type of reflector, which is what I'm into at the moment.
I don't know if you want a decent amount of spill, and I don't know what's best for a zoomie.
I built a zoomie with the T20 host and am using the A17 driver and a yinding led. It works pretty good, but I think I can drive it harder. Remember, smaller led die, longer throw, smaller hotspot, less output. The sft40 will give highest output but decent throw. The yinding gives less output and better throw than the sft40.
Heat is an issue with zoomies since they depend on the body (not the head) as a heatsink. These come with removable pills so if you got ambitious you could machine a new pill our of copper stock with a thicker led shelf for added heatsinking.
could make a good heat sink if I wanted to push it farther but at this point in my life keeping it simple has an appeal. Convoy has a zoom host but I don’t know much about it. Just by the looks and looks alone the convoy doesn’t seem as serious as the other two witch means nothing.
I ordered the following and should be before Halloween I hope. I think that’s it but if you see anything I missed or should change I’m very open to ideas.
1. SFT40 LED,SFT-40-WCS-F50,N5-CE-VJ I got 2 just in case I do something stupid
2. KW CSLNM1.TG 6N-ebxD46-15 6000-6500K same got 2
3.17mm Driver for SST40 ,4 modes 0.1–3–30–100, max current output 5000mA, Temperature protection management inside same again 2
4. 17MM High Output Current 5000mA Driver Board 5A Circuit For SST-40.2
5. Cree XHP70.2 GEN2 High Power LED Emitter Cool White Neutral White Warm White Colors With 20mm 16mm Full Copper MCPCB just something to play with
6. Heavy duty 1mm springs
Thank you for the advise and help from all
