Building battery pack for softair rifle
Hello.
I´ve got an AEG Softair with a battery pack. I bet the batteries are crap, so I wonder if I can build a better one and thought I should ask you guys about it : )
The Battery pack consists of 2x 3 Ni-MH batteries and somehow they are connected. Any idea, which good/budget batteries I could order and how I would connect them to each other to use them with the softair rifle? And could I still use the charger from the rifle or should I get another/better charger for NI-MHs? How could I charge the batteries without having to detach the batteries from eacht other?
Any battery and charger recommendations with a link to a shop?
Thank you : )
I guess you have a MP5 or similar where the battery is in the front part of the rifle, in that case I would go for a rewire of the gun. When I played airsoft the solution when you had those kind of batteries would be to have a bag strapped to the rear part of the rifle (don’t know the english name) and then have the battery in that bag. By doing so you could go with a much bigger battery or maby even a Li-Po pack, which have many benefits. The problem with a Li-Po pack is that you would have to get your self a hobby charger but you could also use it to charge your flashlight batteries.
So that’s what I would do.
It´s a HK 416 and the batteries are in the stock part
Maybe a pair of 18650s wired in series would fit in there without any modifications to the stock?
7.2v shows that all 6 batteries are in series.
Two 18650 series is 8.4v max & could be too much. Some devices are ok with a slightly higher voltage, others burn out. You could search to see if others have tried li-ions in that rifle.
Are the 650 mAh is per 3 pieces or meant for the whole pack of six? I eman, nthe best I can do is increasing the mAhs, right? So basically I need to get 6 better batteries?
How can I connect them? Which batteries would you recommend and which charger? I also wonder if the cables are just soldered to the batteries?
What’s the brand of the rifle? Is it more of a toy than a rifle made for real games? If it’s not a toy it will probably have a gearbox made out of metal and in that case it should have no problem taking a battery with higher voltage which just would do you good. Better response when you start to shot and the rate of fire would go up quite significantly. Considering you already have the battery in the stock I would look in to the possibility of a 7.2V Li-Po pack, either in the stock or in a bag wrapped around the stock. Don’t use 18650, the current draw is to high for those batteries.
Those 6 cells are only rated at 1.2v per cell when at resting voltage but when each cell is fully charged would be about 1.4v to 1.44v each making an 8.4v to 8.64v pack, so using two 18650 batts in series will be fine as that will give 8.4v.
A simpler solution: Airsoft Batteries
:wink:
I have read a lot crap until here….
One easy and good way would be to use 6 eneloops.
The cells are all wired series.
——cell-cell-cell———cell-cell—cell——
The question is how do you charge the cells?
Hi Volk. I’ve been out of the airsoft and paintball scene for a while (equipment is very expensive in Canada), but I remember that a lot of stock airsoft guns come with 15A-20A fuses. There are several affordable IMR 18650 cells that can provide that amount of current
I am also playing airsoft in a somewhat beginner level, and my aeg has a 2s li-po battery installed more than a year ago. It also came with this type of ni-mh.
Imho most of the AEGs use only a strong brushed motor, a mechanical switch(trigger) and a battery, so you are safe to use a slightly higher voltage.
As Default said you can use two IMR cells in series, just check the cells’ voltage regularly and recharge if needed
18650’s may not fit in those battery tubes, especially with the requisite wire down each cell. While I agree with the advisement for two li-ions in series I think 16650’s may serve you better, and you should still have three times your current battery capacity (if you buy relatively new Sanyo’s).
You’re absolutely right that IMR cells could handle the current from an AEG-rifle, I was thinking of ordinary Li-Co cells and that probably wouldn’t work very well. The reason I recommend Li-Po instead of IMR cells is the voltage under load. I was looking in to this a couple of years ago and from what I remember Li-Po cells holds a much higher voltage under load and ad to that that they’re wired with the possibility for balanced charge and I see no reason to use 18650 cells. But you’re absolutely right that it’s doable with IMR cells.
