It might work. Where would you install the “Driver” aka AC to DC power supply?
Be careful when soldering the resistor or wire to the button on the lamp—i found the plastic surround to easily melt before the solder melted. Maybe it is intended to make the solder joint outside the lamp and then press it into the center hole for installation.
Which bin for the LED? Some are not so close to the BBL.
I would install the power supply in the cavity inside the heat sink and just press the wires on the bottom of the bulb.
Why do I need a circuit board?
I couldn’t find the LED bin code.
Quick update here. I received the components. Unfortunately, they sent me the incorrect COB. I ordered 16W 5000K Ra90 and received 12W 4000K Ra95. Fortunately, the seller gave me a full refund.
The driver had a little flicker, so I added one more capacitor.
The COB was a little green, so I added Minus Green filter.
At least the reproduction of reds is good.
(old Philips bulb)
(my light bulb)
I have now ordered this new COB, but something tells me they will send me the wrong specification or a fake one. I wish I could get some SOL or Optisolis COB.
It was 1919 and now I’m waiting for a Cree CXA1816 5000K. The seller assured me that he would send 90CRI one, but he didn’t provide the PN code that I asked.
