Burn marks on XHP50.2?
I noticed a black mark on top of the dome on one emitter in my sofirn q8+. Is this a burn mark and would it spread? I managed to get most of it off by wiping it
Before
After
The LED must get as hot as the sun especially on high or turbo. I am not surprised something like this would happen.
Can you comment on the usage of the light? Did you run it on turbo much? How much was the light used?
Probably a speck of dust burned on top of the silicone layer.
I got it secondhand, they said they used it once, for under 5 minutes.
I’m concerned the burn mark would get bigger
Probably solder flux spatter, which dries up and turns brown when subjected to heat.
Try wiping it again with isopropyl alcohol, which is great at dissolving flux residue. It will probably be fine afterwards as it’s on the dome rather than the phosphor, so it’s not subjected to as high an intensity, and somewhat heatsinked by the dome.
WB, thanh!
