Buy Astrolux EA02 or modd FT03?
Hi all,
I haven’t been very active on this forum or with flashlights on the whole for the past two years so when I started to read about our wonderful hobby again I saw some new (to me…) leds and the rise of the LEP lamps.
The LEPs are (for now?) not for me: quite expensive, just a tiny beam and nothing more.
Interesting concept but at this time not for me, perhaps future developments in this area will make me change my mind.
My Djoz’ modded Thrunite TN31 aspheric with Wavien collar and dedomed GP2 does 1,3 Mcd and I like that just fine.
Anyway, to the topic: I saw ad add for the Astrolux EA02: using the Luminus SFT40 it reached approx 449 kcd on one battery.
Nice ligh, nice format, still quite easy to pocket, take with you on holiday etc.
So my first thought was to buy it.
Then I remembered I bought an Astrolux FT03 “back in the day” with as SST40 - which does 262 kcd with a Keeppower 26650 6000 mAh battery (measured ad Djoz’ place, we both live in Amsterdam which can be very handy :slight_smile:
So I contacted Djoz, went over and he kindly swapped the SST40 for a SFT40 and voila: 449 kcd ANSI (on direct drive/turbo, after 30 seconds). At home I measured just above 500 kcd at start, and 282 kcd at high.
Which means it now has the same throw and output as the EA02 and also it has more throw on high then it used t have on Turbo.
The main difference between the EA02 and the FT03 is in the reflectors: the EA02’s is longer so you have less spill right in front of you. Depending on the situation this can be an advantage as well as a disadvantage: I think the FT03 is more all round.
Conclusion: nice modding outcome and it saved me some money as well.
I highly recommend this modd which is even easier if you have an SFT40 on a board ready, just be careful when you screw the reflector and front cap back on so not to deform the centering ring.
Cheers,
Nico
You must have some big pockets, sir. :laughing:
EA02 is a great thrower. I have the Boost HX version, but sadly have had issues with it. Glad the FT03 mod worked out for you. Sounds like a good combination with the SFT-40.
Haha, I didn’t mean trouser pockets but jacket inner or our outer pockets.
Djoz and I live in Amsterdam, so most of the time we need to wear a coat or a jacket when we go outside.
Compared to the majority of other lights I own the FT03 is quite “pocketable”.
I wouldn’t try to do so with my BTU Shocker… :wink:
Cheers,
Nico
Congrats on a nice and effective mod/swap! I still love the FT03. They brought out a 26800 body tube for those newer long cells and wow…really pretty impressive turbo time and overall run time is much longer than the best 26650 cells. I really like the NarsilM that is on the light but I think they may have changed that on newer editions. There have been a lot of smaller throwy lights the last few years but I think the FT03 still holds its own as a mid range thrower and it’s a pretty good buy still. If you didn’t know, the Mateminco MT35 Mini is the same light, so if Banggood ever stops doing the FT03 or offering parts, Mateminco might still have it around.
It gets even better: I unscrewed the bezel at tiny bit and tapped the side of the head in order to adjust the mprove the allignment of the reflector to the led.
After some attempts (you start thinking why have I even started this……) it worked and I measured the throw again.
It now does 528 kcd on Turbo, right after start up and 272 kcd after 30 seconds on high so more throw on high now then on Turbo before. The beam is neatly focussed with a slight and narrow corona.
Needless to say I’m very pleased with this light and the results.
I love a light this size, with just one (big) battery: still compact enough to carry for a long time or to put in your coat pocket.
And thanks for the heads up on the 26800 tubes, I might just go look for one.
I have two Keeppower 26650 6000 though and they perform very, very well.
Cheers,
Nico
