It´s been quite a long time since I thought about buying a new light. The reason I am weak again is that a friend of mine bought his first light (for geocaching) and it is soo much brighter than my lights!
Back in the days XML-2 was the best I knew of (for the size and the bidget). His light uses an SST40 and now I want one more light that is just as nice.
What would you suggest me to get? I want it mainly for taking walks in the dark forest, using here in there for everything. I prefer a nice smooth floody beam over a sharp throw.
I think I would enjoy the new Convoy C8 with an SST40, but I really want that nice floody light for close ranges. That´s why I think the Convoy S21A with an SST40 could be what I am looking for, right?
I also saw the Convoy S12 with triple SST20 or triple Nichia219. How would they compare to the S21A with one SST40?
If I say the C8 is nice but I prefer the smooth beam, which one would you recommend?
- S21A with SST40
- S12 3x SST20
S12 3x Nichia219
Or is there a different light I should consider? I don´t want to go with a much bigger light if I don´t have to and I also appreciate the low price for the S21 and the S12 : )
Is the XHP70 performing better/ is it brighter than the other options I mentioned?
Do the S21 and the S12 also decrease brightness significantly after a couple of minutes?
Yes and yes. And 3000 on the highest level is quite alot for a single emitter. You would start an ever escalating lumen war with your friend with that light.
If you want a lot of brightness with little step down, I recommend the Convoy M3-C with xhp70 5000k. On the third level, about 1500 lumens it lasts a long time. High is about 4000 lumens or more and also lasts a good amount of time. You can add the tube extension and run 26800 batteries for plenty of mahs. About $40.
Mine also doesn’t overcharge but once the light says its charged the charge rate slows to a crawl and it can take all day to actually fully charge then i need to check the battery to make sure it is fully charged.
I just charge the battery outside the light now.
I have not made any real progress in deciding which one I want : D
So far I like the M3C and the M21E best. I don´t like the angled insets on the M21E´s head and I don´t like that the M3C´s charging seems to be somehow bad AND I am not sure about having a side switch.
However, I have not found something nicer so far.
If you have any additional thoughts, please enlighten (ha!) me.
If you want a tail switch it’s usually mechanical instead of e-switch which will usually rule out built in charging if you care about that.
Maybe take a look at M21D or M21F, if it’s just asthetics you’re looking for. Not sure what the issue with the M3C is, but I believe the driver on all of these will be the same.
Also maybe look at the Wildtrail WT3M, just ordered one of those.
