Hello,
I bought a C8 torch with a 5 mode driver. It runs off of 1 18560 battery. I was wondering how do I take out the driver to change it? I want to switch it to a single mode. Does it just unscrew with ring pliers or something? Thanks.
Yeah you can remove the bezel, lens and reflector through the front.
After this disassembly you normally can see the pill in which the led and driver sits in. The pill can be unscrewed.
OR
You can unscrew the battery tube, now you should see the driver. If you can get it out you can replace it without disassembling the whole light…
Correct, but how do you get it out? Is there a special tool need?
usually the driver is press-fit, a small screwdriver will do the job
It may have a small driver retaining piece that screws on over the driver. This may be glued on.
http://www.fasttech.com/products/0/10002463/1277302-convoy-c8-diy-led-flashlight-host
This listing shows the piece I’m referring to in the second to last picture.
Thanks all.
Now another question. I was looking to get a HS-802 in red. But just hear they do not make a CREE LED in XRE-R2 in red, but they do in green. Is this correct?
