So I’m building a CNC machine that I will be able to use as a lathe. I need some CAD test files. I assume there are open source EDC flashlight body designs around here. How do I find some?
You can find some on grabcad.com, but I don’t think these are production models with correct tolerances. More like presentation models.
You could make your own, Fusion 360 is free for hobby projects and it’s not that hard to learn.
Yea I was worried too that GrabCad was just mockups. I could sure make one, but with all the threading and detail it’s not worth it just to test the lathe.
I cant help with any files Josh but am looking forward to seeing the lathe itself. ![]()
Yea I can post when it is finally done. It takes so long to get laser cut metal parts fabricated and shipped. That’s the real reason I started the project, but adding lathe abilities was irresistible ![]()
You’re also welcome to show your build so far, maybe we can give some comments to improve the design.
Usually hybrid machines, for example a lathe and a milling machine, are not a good idea for us makers. It sounds like you are adding a lathe functionality to a laser cutter somehow, which will very likely not work out. I apologise though if I completely misunderstood your project.
I have some (more like loads of) CAD files for flashlights. But they are made for my conventional lathe and don’t contain threads. So you would have to add those and possibly some other minor details.
It’s not a laser system, it is first and foremost an abrasive waterjet for steel. There will be no compromise on that functionality. And I am adding a Dremel holder in case I ever want to do a 3D carving project. And why not rotational carving? So that’s what this post is about. If you have a simple flashlight design with no threads I would love to have a look at it.
The 3 best technologies for steel cutting are laser, plasma, and waterjet. US citizens have to jump through hoops to get lasers that powerful, and they also require more power than a home garage is wired for. Plasma is nice, but splashes molten metal and leaves a melted edge. Waterjet cuts anything perfect, and only has feed rate as a setting. It’s quick to start a job. It is slow to cut, yes, but waiting 2 weeks for job-shop laser parts is NOT near as fast as a few hours on a waterjet.
Interesting, I wish you the best of luck then!
I should have the files for all the lights displayed there: Some Custom lights - New update 25.07.2015
Also quite a few more. Any particular wishes like battery size, e-switch or clicky, or amount of emitters? ![]()
Thanks!
I think this one is pretty cool. And it requires some accurate indexing to cut the slots near the top.
don’t we have a Q8 head CAD file somewhere? maybe a generation before actual production CAD.
Sure you want to start with a whole flashlight?
I have seen models that are used to test the accuracy of 3D printers, arent there models to use in machins that remove instead of add? with known sizes so one can test the machine before making something harder.
Yea after some more thinking, pulling a flashlight out of solid metal is a bit ambitions for a starter project…
Wellp, like Michelangelo said about sculpting, the statue is already there in the marble, and all he has to do is remove the extra bits to set it free.
So it is with a flashlight and a hunk of aluminum…
Well I still can send you the CAD files if you want to. Otherwise you can also just later hit me up with a PM ![]()
I will PM you. That way I can import them into the Solidworks model and check everything. The ‘build’ is just a CAD model so far. I love CAD modeling, and I am very good at it ![]()
