Can anyone ID what flashlights these are from?
Hi BLF,
Can anyone identify what some of these components may be from? They were from a batch of parts that I got recently; I thought some might be HDS but the thread pitch and count don’t fit my HDS EDC or Rotary; perhaps these components are from much older models and other manufacturers?
Any suggestions as to what these could be, do let me know. I’d be grateful of any tips.
Wow, that looks difficult.
Good luck in your quest! :upside_down_face:
Just a bit! Though some of those shapes seem really quite unusual (like 6, 8 and 9) so I’m hoping they might trigger a memory somewhere.
8 and 9 should come up with Google lens, they look like parts from some Arc flashlights.
Surprised #3 isn’t compatible, it looks very much like a HDS light part, perhaps the threads changed at some point?
Great work, looks like you’re on it with the ARC flashlights, possibly for 8 (2AA tube for LSL-ST), 9 (ARC of some sort) and 10 (LS2 switch).
I had tried Google Lens and some other AI models but they seemed to get stuck on Surefire and Maglite!
Looking up ARCs, I think this link may have also identified 11, as a switch possibly from an HDS EDC Ultimate 60 (or other related model):
I’ll email Henry and see if he is able to help with the thread pitch aspects, and if any components are interchangable with different HDS models. I had really hoped one of the extension tubes might be for HDS but it seems not.
Many thanks for the ID Gravelmonkey
#7 looks like a 17670 tube for Novatacs. Seems to be missing a signal spring.
#4/5 look like suefire C or 6p body 1 cell extenders
#1,2,3,11 look like some legacy iteration of HDS…go to hdssystems and look at the list of legacy products.
#8/9/10 as another member stated, either arc or liteflux, heavily biased toward arc, 8/9 with kroll switches
6…12…look soooo familiar, but can’t quite place them…
Brilliant, thank you Dc38. Looks like you’ve nailed them. And your mention of LiteFlux has I think resolved #6, looks like it’s an LF3XT 2xAA battery tube.
based purely on the machining aspects of #12, such as knurling, threads, oring placement, I’d say it looks reminiscent of ARC, particularly the flat tailcap…
Maybe for a larger bore body, 17 or 18mm cells?
I had just found ONE photo, but accidentally pulled down to refresh and now it’s gone to the aether…sorry!
Interesting, and I see what you mean in terms of the machining in the context of the other ARC parts here, it looks like it just hasn’t been anodised. Shame I don’t own any ARC or HDS-compatible flashlights to put these to good use!
I really appreciate all your responses Dc38 and gravelmonkey, thank you.
Ah yes! Something about the wire clip and machining reminded me of an old brand but I couldn’t remember which at the time I posted, it’s absolutely Liteflux I was trying to remember.
Some very unusual parts, wonder what happened to the heads?!
The LiteFlux one is quite an odd extension - it’s almost like they were trying to make it look like it was made up of as many different machined sections in one as possible!
Henry of HDS fame has very kindly responded confirming that #1, 2 and 3 are from a Ra/EDC Clicky whilst #11 is from the EDC Ultimate/Basic. They do indeed use different thread types (24 V profile and 32 V profile respectively per inch) from one another and from more recent models.
For the heads, it wouldn’t surprise me if they were sold off separately at some point accidentally, or possibly these are additional components for what were complete flashlights. The extraordinary collector this batch came from sadly passed away some time ago, and his partner has been going through it to the best of her ability keeping things together but inevitably spare parts will get separated sometimes. I’ll see if any of these can be associated with anything she can recall letting go of.
Thank you all once again for solving this puzzle.
Just found the signal spring in the box!
I want to say I saw these for sale over a CPF a little while ago…I wouldn’t doubt that with the interoperability of each set of components within their own lineups, the heads were probably modded or on different lights. That liteflux body in particular looks awesome!
N 6, probably LiteFlux LF3XT … !?
speaking of…do you happen to have the cottonpickers lcd screen charger from that bundle? lol
Yes, it does look to be a battery extender for that one
The Cottonpickers is partly what drew me to the bundle (along with the suspected HDS parts as spares), even though I didn’t know exactly what it was, I just suspected it would be useful and it certainly is. Charging an 18650 just yesterday with it and using it as a voltage tester on a 21700 light too. It’s a great device.
Like you, I suspect the heads are long gone with myraid other components from the same parts. Jan has certainly tried to keep things together, but it must be very difficult if there’s no paper trail after the sad passing of her partner.
