My Makita MAC700's plastic shroud broke on 2 of it's mounts. Instead of spending $32 on a replacement, I'd like to try and glue it. I'm not sure what kind of plastic it is, but it's a little flexible if that's any help.
If it melts, welding is the way to go. A soldering iron with an old nasty tip will do it. I've backed welded seams with hot glue, and it's holding up so far.
Try Araldite. its very good adhesive. there are 5 minutes and 90 minutes epoxies available.
I tried several other brands looks like Araldite copies. but adhesive strength is not good. some epoxies doesn’t hard like rock.
Thanks! I'll try welding it tomorrow with my SMD hot air rework station. Hopefully that works :) If it doesn't I'll try the epoxy Pavithra_u recommended, or something similar.
Another thing you can do is to use a Plastic clothes hanger for extra plastic, to fill in the seam. Using a soldering iron is probably easiest and using a plastic clothes hanger as extra to fill in with may work, depending on the type of plastic that your Makita is made of. I usually melt some of the hanger on my iron and then run that against the seam till it all melts together and I just try to smooth it all after, with the iron.
Another good idea. Thanks Justin :) I will give it a go tomorrow when I have some time. I had to take the whole thing apart in order to get the shroud off. Oh well
http://img163.imageshack.us/img163/2897/rym3.jpg
Used this method on various plastic pieces, to re join broken handles, fill in holes of buckets, fix toys of my daughter …
Have used other soft plastics as ‘solder’ but this cloth hanger idea is great address.
Well, I ended welding it with my SMD hot air reflow station. Also put a huge bead of hot glue on the inside where it doesn't show. Then I re-melted the hot glue with my reflow station getting the plastic very hot making sure it has a strong bond. It's back together now. Hopefully it lasts. If not, I'll just buy a replacement.
