Can anyone use these batteries?
*** Update *** These batteries were shipped out today.
I accidently got the battery pack wet while cleaning my Dyson V8 vacuum, so I ordered a new battery pack. I took apart the wet pack and now have six of these batteries, all reading around 4 volts. No idea on capacity. Pretty sure they are 21700 size. I already have several Dyson 20700 batteries (pictured) and about ten 18650’s on hand. So, I don’t need these. They need a little TLC, to clean off the foam and remove the soldered metal parts.
I have two flashlights that came with a little plastic sleeve so an 18650 will size up and work. For those lights, these 21700 size fit perfect…at least for the two lights I have they fit.
If someone will reimburse me for shipping, I’ll send them out. UPS Ground only.
Let me know. Shipping from North Texas to you should be about $7-8, but I won’t know for sure until I make a shipping label.
The first pic shows what I will send. The second pic is for size reference only. I’m not shipping out the Dyson, the pink or the purple ones.
This was the label on the battery pack.
Happy to take them off your hands .
…. PM sent
Received these cells today .
Cleaned them up and put 4 on the charger. They were about 4 volts and i noted the internal resistance on them .
The first cell was 16 mR
#2 had 18 mR
#3 had 18mR
#4 had 30mR
The numbers are so good I’m not even going to bother doing a full test on these .
Thanks again
Wish I understood what all that means, but it sounds like you are happy with them.
Low internal resistance is a way of measuring the well-being of the cell .
A low resistance cell is like a glass that’s empty and can take a full 16 oz of water. The high the resistance is like a glass thats got a massive amount of calcium build up so you can only get 8 oz. Into the glass and 8oz. Out . The capacity is degraded .
Feel free to join my weakly battery for dummies discussion .
Cells with a low Internal resistance is a very good sign of overall health .
  • the last two are 16mR and 22mR
  • Both just great numbers .
    The chargers that tell you internal resistance are to be taken with a grain of salt but can give you an idea of the general state of health when compared against everything else thrown in the charger .
  • the cells came almost fully charged and internal resistance numbers of cells with higher voltage in them almost always produce better / lower numbers.
    Hopefully someone smart will come along and explain where I’m wrong .
Thanks again
