That’s no problem, your probably right
With regards to the dynamic control, if monies no object then I say if you like it and how it drives over the car without it then get it,
But if you have better, or more important things you could use the 5 grand for, then don’t get it
Personally I don’t think it’s worth 5 grand, one or maybe 2 at a pinch, but not 5 large
I had a Audi a3 and I thought the standard suspension was great, especially on the fast twisty roads, was maybe a little bumpy on some roads, but that may have been more to do with the bigger wheels and low profile tyres than the suspension, plus the state of the UK’s roads if you can call then that, would make a third world tin pot dictator embarrassed
As for the eBay links you posted, that is what they call the lite vagcom diagnostic, it’s pretty much shareware and is not much more than a normal obd2 diagnostic designed just for VAG cars
You need Vag com 12.12 or higher due to you car being so new
Try aliexpress they always have then, I can’t really give you a link as they are always coming and going, just buy one that has lots of good reviews as they can be a bit hit and miss but if you find a good seller you should be fine
Don’t buy of ebay, they are normally sold by crappie Chinese seller’s or locals in whatever country at a vastly inflated price and have normally come from crappie Chinese seller’s in the first place
(nothing against Chinese seller’s I buy a lot if stuff from Chinese seller’s and they are great and the items are normally good, it’s just my experience with vag com has shown me that the Chinese seller’s on ebay of vag com, take your money, send you old or non working Vag com and disappear)
Your other option is to buy a vag com from Ross tech, it’s not much money from them, you get the genuine original article (they design and built/programmed vagcom in the first place and all the copies use cloned Ross tech software) and full technical support and updates, and in the great scheme of things it’s a fraction of what your spending on a a3, that is who my brother got ours from and why I have a new one still in the box
But it’s up to you, if it was me I’d probably buy one from aliexpress if you find it useful, maybe think about getting the genuine one from Ross tech for the support and updates
but it’s your choice
hope you find the info useful or you want to know the codes to use to reprogram your a3 to get the hidden features let me know
One final thing and this is important, take screen shots of the old codes before you hit the do it button and put in the new codes
It will all make sense when you use, but whilst you can’t break your car by recoding it,you can stop things working or immobilise it if you put the wrong code, but don’t let that worry you as long as you have screen shots of the old codes you can simply put them in and it’s all good again
Or post up and I’ll be able to give you the codes or unfixed whatever you did
Apologies to anyone with no interest in cars, if I rambled on a bit long
