Can I Charge/Test Individual Cells in a 2S2P Bike Battery Like This?
I think I can do this, but would like some confirmation first. I believe someone else once told me I could do this, but I was confused what they meant at the time. I have a 2S2P bike battery pack which I have unwrapped to inspect. First of all, you may notice that the cells are connected wrong. Well that's ok, the two darker wrapped cells are just dummy cells! They measure 0.00v across them. For this question though, let's assume they are connected properly. (Actually my wiring would be different for a proper 2S2P pack, because I guess I'd be connecting to two parallel cells instead.)
Ok, back to my issue. Can I connect up my OPUS like shown below to charge/discharge test the two cells shown?
First cell:
Second Cell:
In case you wanted to see the other end of the pack:
My charging wiring was just thrown in place to show my intention; I'll tidy up the connections better later.
I want to charge these cells individually because they are way off balance (after "full" charge they are at 4.19v and 3.79v). I then want to discharge test them. I'm trying to avoid disconnecting the "2S2P" tabs.
Thanks,
Garry
With a pack made of 2 dummy cells and that far out of balance to boot, I’d say the pack is not very good and the balance/protection mechanism isn’t even working. I’d clip the solder tabs, take it apart, test the cells individually, then decide whether to put it back together or chuck the lot. Frankly I think you’d be better off with a new build and decent cells. From what I gather many of the bike pack cells are “bike-fire”.
But to answer, yes your test should work.
Minimally you can simply cut off the dummy cells.
This battery pack came with a bike light I am in process of reviewing. I have no intention of actually putting it to use after the review.
Yes, I know the pack is junk. I have done some charging and runtime testing of the light and pack though and it does "work" without getting hot, venting, or anything. I do wonder how many of these "bikefire" battery packs are out there in daily use with the users non the wiser!
-Garry
I have a similar battery pack with four “real” 18650s in a 2S2P setup. The cells are marked as 1800mAh and their capacities are reasonably close to each other when tested on my hobby charger. As flydriver mentioned, you could charge the cells in the manner you suggested if you’re confident about the capacities of the cells, but ultimately it may be easier and safer to use a dedicated cell holder with a set of four matched cells.
My biggest concern at the moment is the battery tabs leading to the PCB for the two working cells. Unless my eyes deceive me, it doesn’t look like there is any isolation between the tabs, and they appear to be dangerously close to each other. A small nudge or a lead getting loose could cause a short!
Thanks for the responses!
Got one already which is my goto bike battery solution. Like I said previously, right now I'm only concerned about this particular pack for the review.
They are actually very stiff and sturdy and would take an awful lot to nudge them together. They do get wrapped over with that thick black tape and that pcb falls in the "valley" of the two cells when shrink wrapped.
I don't believe this pcb has any kind of balancing circuitry. I believe it just has overcharging and over-discharging protection. I've not tested it for overcharging protection, but I have had it kick in for over-discharging - at 5.50v under load (6.80v after load is removed and protection reset).
-Garry
Without the PCB involved, you should be able to test each cell, individually, given the wiring scheme you picture, provided that you only test one cell at a time.
With the PCB involved, who knows? I have no idea what it might be doing, and so no idea what will happen when you try running a charge or discharge with the Opus.
Garry it is perfectly OK to test each cell that way. PCB is not involved in any way as there is no flow through it. I'm curious what the capacity is. My guess is about 1500mAh at max.
I'm currently charging up the low cell now. Will report discharges when completed (I don't expect it will take long :) ).
-Garry
Thanks for the insight Gauss! I agree with your concerns. I would never recommend cheap packs.
First cell finished discharging @ 1.0A on my OPUS v2.1 and has really surprised me!
2200mAh! That's pretty good for a cell in a cheap pack!
Recharging cell#1 now and will discharge test the other one next.
-Garry
How can you be sure there is no flow through it? There are separate conductors to the positive and negative ends of the series circuit, and then another conductor from the PCB to the tie between series connection between the cells.
It is simple. If there would be any flow then the cells would get empty by itself ie. with no load. To get flow throught the PCB you need to connect the load (light) to the PCB output cable.
Maybe someone already said, but if not… this is =NOT= a 2S2P pack. it is a 2S1P pack with 2 spare cells attached in parallel.
There should be a protection circuit bridging the “spare” cells. This is why you are getting the erroneous readings… one pair of cells never gets charged, or discharged.
Edit: Okay, you already realized this is a scam pack with the 2 dud cells. Why in the hell would any manufacturer do this?
To scam us? :Sp
You’ve seen those fake Ultrafire cells with a tiny battery inside and stuffed with unknown powder? Seems it would be more trouble to do that than just make a battery.
Test of the second cell is in: 2099mAh. Is that too much different from the first one to consider them a matched pair? I'm considering carefully opening the dud cells to see the insides. Think I'm okay to do so? I'm thinking to use a pipe/tubing cutter close to the negative end.
-Garry
maybe duds found during qc? i would cut em open.
i would get closely matched replacements and make a new 2s 2p .
use the 2 good but mismatched cells in single cell lights.
mark them to see how they do in the future.
I was thinking, using cells pulled from NOS laptop packs would be good candidates for building/rebuilding 2S2P battery packs due to some of the tabs already being welded on. I'll post back if I do cut these open I suspect they'll just be empty.
-Garry
yes nos,quality cells already paired for you.thats exactly how i would do it here.
Well, I cut open the cell. By the way, it has/had zero conductivity + pole to - end (I thought it did originally). No sparks, no venting, no flames, no explosions, no fun .
This is NOT what an 18650 should look like inside, is it? Isn't this just some filler powder? The cell was pretty light weight, but not as light as some UltraFire cells I once had. I thought it was going to be empty.
-Garry
its same as a scam ultrafire without the tiny lipo.
dirt filled dummies.
I’m thinking they are smuggling drugs. Are you seeing things yet?
Or you should put a Geiger counter next to it just to make sure you haven’t been sterilized.
