Can I Cut the wire and wire it into a 12 volt battery.
I would like to mount this light to my quad steering column with 12 volt quad battery power instead of batteries. I just want to make sure it will work.
I want to make my own light. but i cant seem to find big reflectors that would be good for driving offroad at night. I currently have HIDs on it but i need some good throw as i have a lot of flood from the hids in the headlights. Any recommendations on what reflector would be good. i want to go xml-u2 and a 18v driver. I’m a new to the components of led flashlights
Bollow is what I want to mod for my quad.
http://www.cnqualitygoods.com/goods.php?id=1842
A couple of these will throw pretty good and are off road with BIG reflectors
http://www.opticsplanet.com/lightforce-240mm-driving-light.html?gclid=CJKT6OW5kbYCFSGqPAodyH0A5w&ef_id=UUzlwAAAAfwmh4At:20130322231408:s
Hi,
That light takes 4x18650, but they could be in parallel or some combination of series-parallel in the pack, so I think that you should try to measure the output of the fully-charged battery pack to see what that is.
If it’s in the 16v range, then it seems like it should be ok, voltage-wise.
However, it’s been awhile, but I think that with the car battery, there may be surges, like when you start the car, etc. I don’t remember what it was, but I was trying to hook something to the car battery (in a car).
Jim
You could use this drive it. From the same store.
So can this driver be used with a 12v automotive type source or just a string of li-ions?
Yes, it can be used with a 12v battery.
I think you could use it with a bunch of li-ions as well. I’m not great with this stuff but from the looks of it the board it has a TVS diode wired right into the positive input, which should be enough to prevent voltage spikes.
I’m using a pair of these on my motorcycle…
27W offroad LEDs
The light output is very impressive for the size of them, you could say. :slight_smile:
But my next purchase of these will be the larger ones…
48W offroad LEDs
