Its like a little clip which fits inside your pocket so you can hang it to a something like a Swiss Army knife so it wont fall out of your pocket? (Put hangs down inside your pocket.)
I remember seeing them once, but cant find the place I bookmarked, and would like a recommendation to the “good kind” if there are different types of quality, etc.
Im in Canada so its usually expensive to order from the States so I like the Chinese vendors, thanks!!!
Also please since this is a budget forum please recommend a budget or clone version - Im sure some heavy EDC guys buy 50$ titanium clips like this, Id like something a lot cheaper.
+1000000000 BLF has actual honest users who give good advice so I always like to ask here, I know its very low chance to get bad recommendation on anything.
Thanks guys, going to check out these links and order some! Im going to start carrying my little AAA and dont want to loose it.
Cheaper still is a teaspoon handle, drilled bent and a split ring added.
I’ve got one of the P7 types as well as the seven clips on one type. The one that Isti242 links to is a heavy duty clip.
They all work very well.
There are some almost square split rings availabe from tec accessories that are oval to oblong shaped they lay a lot flatter in the pocket so are less bulky. Split rings.
The ones from Tandy I’ve not seen before, I’m pleased to see that the black ones are available and at a reasonable price.
