Can you identify these pins and connectors?
I was hoping to add some of these pins and connectors to my next Mouser order, but I can’t seem to look them up. I’m looking for the 2-pin through hole connector, the mating housing, and the female crimp-style pins. Any help would be much appreciated. Thanks.
Oh, crap. They call those “JRC” connectors or something. Can’t recall offhand.
Used on the ends of LiPo cells sometimes, other power-connections.
Missed it by that →← much…
Try “JST connector”.
JRC isn’t working out. I previously tried JST, but with no luck either.
I’ll have another look when I return, I’m going to be on the road the next hour or so.
Don’t really know but this looks a little similar:
https://www.aliexpress.com/item/32727247531.html?spm=a2g0o.productlist.0.0.ceb550c7bMbzIZ&algo_pvid=0e197a3f-f6e1-4381-bcfb-99a7ea8828fa&algo_expid=0e197a3f-f6e1-4381-bcfb-99a7ea8828fa-16&btsid=0ab6fb8315819754755726159edfbe&ws_ab_test=searchweb0_0,searchweb201602*,searchweb201603*
https://www.ebay.com/itm/XH-2-Pin-15cm-18AWG-wire-lead-JST-Female-Connector-plug-for-3D-Printer-Fan-x-5/123557443927
Yeh, there are like a brazillion ever-so-slight variations that make it a nightmare to try to find the exact one.
’Though remember those digital displays on computers where you could switch the clock speed, eg, 25MHz, 12MHz, and 5MHz, and it’d display “25”, “12”, “5”, respectively?
Those LED modules just like in the pic would take those connectors, so if LiPo doesn’t dig up anything useful, try those. Ancient history, but…
Thanks guys. From Moderator007’s link I was able to determine it’s for sure called a “JST XH 2-Pin” connector.
Success! Thanks guys.
