can you identify this sky ray? 3xXML 3x18650
http://wallbuys.com/Product/SkyRay-CREE-XM-L-T6-5-Mode-Waterproof-3-LED-Flashlight-Black-3-x-18650—6647
like the title states, can anyone identify this light? or an exact clone?
im hoping to get some internal pics or a review or something
it’s a new one on me, shame its on wallbuys, I wont be putting money in those spam artists pockets. I looks to be tail clicky on/off and side clicky mode switching so fitting a decent driver would be an issue, also, other electronic switch skyrays have had a disappointing ui.
ive been wanting the shadow sl3 for my first multi emitter, but im not going to have the funds for it. so i figured i would hop on this sky ray for my first at $25. despise the looks of the SRK, so i thought this would do for now
edit: maybe i can do something like this. have the tail as a master switch to cut power from the side switch LED. could be sort of like a crelant form factor with out the ramping
the difficult thing is there are not many drivers that support both tailcap on off and sideswitch mode selection, perhaps a master slave dr jones set up would work though.
nah, i was thinking of using the tail switch to switch on/off the neg end, and maybe a contact plate on the pos end to a latching switch on the side to switch the positive end.
could wire it up so the main power(tail switch) would power up the light on the side switch. the light on the switch will turn on, and you could then control power to the driver with the new latching side switch
im thinking something like this would look bad@$$
not sure how this idea will work though
or i could even use a normally closed switch in the side switch location, quick presses will cut power to change modes with out the chance of it latching and shutting the light off by accident.
just some ideas running through my head. should probably wait and get the light before i get too involved in it
With a two switch setup the cleanest solution is a dedicated-momentary-switch driver, and only use the tailcap clickie as a lockout button.
edit: DrJones has one for that switch config too, but it's still limited to 3-4.2v input: lumo35drv
im guessing thats for a normally open switch?
like i said, i should probably wait on the light to arrive before i get to involved in it, but that driver looks nice! i would probably need a driver/slave set up though? ive read about them here and there, but still dont understand how they work.
Yes momentary switches are normally open, they don't carry any of the current they just send a low level signal to the driver telling it to do something.
The master/slave thing is simple. There's one board with the MCU, and however many single-mode slave boards. The master's PWM output is jumpered to the PWM pins on the slave boards. So when the master board changes modes, it also commands the slave boards to do the same.
