Well, I decided to make a own thread for this.
Gotta be tons of those LEO threads at CPF, not going there. Trusting the pro´s in here ;)
My friend at work needs a light (I´m not a guard, just happen to do nightshifts and he checks our factory also).
He used to have Mag charger updated recently to my previous 2D Lambda XM-L at belt for long range.
He also uses an Urnabeam 18650 (Q3 ?) as a lighter option for navigating in dark places indoors.
This smaller light is going to be updated now.
Need recommendations with these specs:
Battery should be 18650 x1.
LED preferrably XM-L, R5 is not totally disapproved either. R5 might be in consideration because I believe he needs runtime more than absolute lumens.
If he has done it with Q3, no need to get 3A from XM-L. Naturally, a properly driven XM-L will beat R5 in lumens and efficacy, if such is to be found meeting these criteria.
Not looking for ultimate thrower, since he has one already at belt (well, decent thrower at least...) and this would be nost likely at indoors use.
Runtime should be at least 1 hour but more likely 1+ -> 2h.
Light is used mostly bare handed, so tactical button is not a must.
Tint is almost irrelevant, no blues or greens.
PWM not an issue at the moment, I believe.
Previous light is 1-mode. If used in "fast situations" should the new one perhaps have an option or mode group for momentary High-only or 1-mode group?
Budget: Does NOT necessarily have to be the most budget of them since it will serve probably for a long time. I think 100$ could be a theoretical limit.
Long story, plenty of specs.
After night shift, only things popping into my exhausted mind are Zebralight SC-600, N-Light ST50, brand "Clarus" for some reason.
Gotta get some sleep now, thanks for help! :)
