I got 4x NCRB 18650B Panasonic 3400 mah green in my TK 75 2900lm. At what point, lets say 50% charge, do i start to lose output? is it at once after 10 mins turn runtime lets say? or its happening only when you get to like 25% charge left?
Sorry, i’m not really good at reading graphs….basiacally i want to compare Shocker vs TK 75, but not sure do they have to be fully charged or at least 80-90% to make fair compassion?
I'm no expert, but it's my understanding that you'll start to lose output where the voltage of the battery under load falls below the voltage required for that max output (which will of course vary from light to light). This is why some high performance cells can give higher outputs than some "regular" cells (ie. Samsung 20R's compared to Panasonic 3400's). So I guess you'd have to use the same cells in each light and best to test with fully charged cells in each.
The design of the driver has a lot of effect on this as well. Some drivers hold tight regulation throughout the discharge time of the battery. Others are loosely regulated, more of a current limiter than a regulator, and will allow the current through the LED to drop as the cell voltage drops.
This is why I’m considering 2 batteries in series for some of my torches.
Because, when a single cell runs low, towards, say, 3.2 Volts, there’s not enough tension to push that current, for which you would need, say, 3.6 Volts.
With 2 in series there is always at least 5.5 Volts to start with.
Otherwise you’ll probably need a boost driver to get full power from 4.2 to 2.75 Volts…
Or just run ‘em low.
An ’every day carry’ doesn’t need more than 3 Watts i.m.h.o.
But I live in an urban area, where it’s never completely dark anyway.
