Change C8+ KB CSLNM1.14 to XP-L HI
Hi,
I got a Convoy C8+ with the blue KB CSLNM1.14 emitter installed with a smooth reflector.
The blue is cool, but I don’t find it very useful. I am considering replacing the LED with an XP-L HI (or maybe HD).
I like throw, but really would rather get as much flood out of the thing as I can get. I also will not obsess over beam quality.
Which would be better?
It has one of the 3/5 mode drivers in there from Convoy.
So what I would like to know before buying parts is what all will I need to do?
Is the stock driver OK? I haven’t been able to find anything specific on the current output. I am not concerned about maxing things out, but I also don’t want to kill my new XP-L either.
Reliability and less heat over max lumens for this one.
If not, what driver would be recommended for this build?
Will I need a new spacer under the reflector, or maybe modify the one for the OSRAM LED?
I haven’t done any modding since the days of the P60 So I am just trying to get info to save myself headaches.
The driver you have is OK. You can get more brightness and a better UI by grabbing a 5A 12 Group (17mm “for SST40”) driver from Convoy with your order. For lower heat generation you can always use a lower mode.
You will need a new centering gasket when going from an Osram NM1 to an XPL. Between XPL-HI and XPL-HD, XPL-HD will give you a little bit more brightness and a floodier beam compared to XPL-HI. It’ll definitely still be a thrower though.
You want white? Carve up a remote-phosphor LED lightbulb, cut one of the panels to shape, and while it’d stick out like an aspheric lens, you’d get a nice floody white out of it.
I’ve had a few C8’s over the years and a C8 with SMO reflector and XPL-HI driven at 6 amp or even with FET, due to xpl’s higher vf, is still a great and under rated light. Plenty of throw in the beam without it being pencil thin and loads of CCT’s and tints to go at, 4D being a fave. Also cheap, also great form factor.
If you do swap the emitter remember the all important spacer gasket, worth getting a few different types as xpl is 3535 size. Different spacers give slightly different beams, usually in the corona. Wrong spacer can put rings in beam.
Thanks for the replies
I ordered an orange peel reflector and XP-L adapter. From Mountain Electronics
I also got and CREE XP-L V6 3D LED on Noctigon 20mm MCPCB
and their FET Driver - 17mm
I wasn’t really sure about the driver, but I can get it more quickly than from the Convoy store. Will it be OK with the XP-L?
If not, I can order one of the Convoy drivers … 5A 12 Group.
Or I was thinking about the DrJones H17Fx Driver. How would that one be with the above?
Not sure about how well the finances work out. I could buy a New C8+ for not much more… :stuck_out_tongue:
Thanks again.
The XP-L will work just fine with a FET, FET+1, or H17Fx driver.
I’d have gone for more throw, but yeah that will work.
H17fx is overkill for a thrower, I usually only want high/low or simple settings, it’s a great driver though.
Best thing about C8 is, you can change your mind.
Thanks,
I am looking for something with a little more flood anyway. My lights are used more for close in work. I am in an urban setting.
For example, one of my favorites is my MT07vn with the XP-L2 leds in it on low modes for just navigating the house at night.
My back yard is only about 40X60 meters, for instance.
But as you said, I can make changes going forward if I don’t like what I have. I will still have the smooth reflector for a quick and easy change there.
I was just really trying to make sure I didn’t turn the thing on and kill the LED immediately.
I’ve never killed an led with fet. The only leds I’ve found to be very current sensitive are 219b’s.
Post updates, let us know how it goes.
Well, I swapped out the LED to the XP-l HD and changed to a LOP reflector. I figured out that it has the Convoy 12 mode driver (4800 mah). So I am getting 6 levels. But low is not as low as I would like.
I also think it could get brighter, so I will swap in the FET+1 driver soon.
But all in all it is not bad as it is. I know some think this light is better as a pure thrower, but for my use this setup works well. Just need a bit more on the low end and at the top, if I can get it.
I think the MTN17DDm driver with Guppydrv Rev.2 may get me that.
Or can someone recommend a better 17mm driver for the setup? Range of levels, top end brightness, and efficiency.
I know, I don’t ask for much…
@Mandrake50, if you really want flood, I would actually recommend the LH351D.
It’s a very efficient LED (even more than the XP-L HD actually), and has slightly lower VF, meaning you get better regulation out of it.
Here are the upgrades you can therefore do:
1. Change the XP-L HD to an LH351D 5000k 70CRI.
2. Change the springs for lower resistance ones/do spring bypasses.
3. Get a higher power/better regulated driver.
Easiest solution for flood is to plug a silicone diffuser to the head, that way you can easily switch and use the flashlight as a lantern, it also slightly lower the tint.
I do intend to bypass the springs. I was just researching this. I have everything that I need to do it.
I will check out the LH351D that you mentioned, but I need to find one mounted. Any suggestions on a source?
I have been so much reading about drivers that I am confused. Any suggestions in a direction to go for that? Other than the FET+1 that I already have?
