Charger for a newbie? Milboxer?
I have an old Nitecore i4 (v2 I think) from my short vaping stint some years back. Since this charger can only charge up to a 18650 and I am sure I will get bigger lights requiring bigger batteries :innocent: I figure I may want to swap chargers.
I did some searching and found the Miboxer C4-12 - I like the features of that quite a bit. It tells you the current voltage, it manages speed, the voltage is not shared, it can do tests, and can discharge as well… (seemingly perfect for an electrically challenged newbie)
Seems Amazon has it for $45 - before I just jump to buy this one, are there other units that are similar in features, and supports the various battery sizes etc that I should look at?
TIA - you guys have been amazingly helpful so far.
  1. update - I ended up going with the OPUS
The C4-12 u mentioned can do test and discharge???
No discharge is possible.
That’s my understanding too…
I have a “Youshiko YC6000 Professional” charger. It does charge/test/discharge and it’s a nice bit of kit. I’m sure I’ve seen it under different guises from AliExpress/BangGood as well.
Which cells are you intending to use? 21700 should be fine with your charger.
