I’ll certainly defer to anyone with better knowledge of this cell but 1A sounds like a lot to me. Perhaps 0.5A first to see if it gets more than a bit warm? If it does, stop there. If the cell stays cool then you could try 1A and see if it gets more than a bit warm. If not then it might be okay.
You can certainly “fast charge” cells, and allowing them to get very warm to hot, but it ages them a lot faster and increases the risk of using them over time.
I am unsure if 500mA or 1A will trip (permanently) the PCB on that cell since it’s onboard circuit draws only around 0.33-0.35mA during charging via USB-C.
I did a thread search and could not find an answer specific to this
oh well I guess I will buy some unprotected 14500 cells
The add-on protection boards won’t interfere with an external charger’s normal operation since the protection pcb is there only for faults like overvoltage, overcurrent, short-circuit, and sometimes over/undertemperature.
Oh, wait…my bad…you’re referring to the USB charging PCB’s added to a cell. They work through the USB port and charging via the cell’s end terminals shouldn’t be a problem. If the external charger reaches too high a voltage or you charge too quickly then, maybe, the usb charging circuit will sense this and disconnect the external from the cell (via a MOSFET switch). There is also a chance that charging with an external charger completely bypasses the on-board USB charging/protection circuit.
Because of these unknowns I recommend that the cell’s instructions/user guide always be followed.
I charged a Lumintop 14500 with USB-C in y LiitoKala more than once - cell works fine. As far as I know, the USB charging is just parallel to the poles. So it sees battery voltage all the time, whether or not you push current in from the outside does not matter.
I rarely ever use the USB port on batteries, although I also don’t charge 14500s at 1A anyway, regardless of type, and go to max 500mA there, but I’ve never had a USB battery I couldn’t charge normally.
