charging these 18650's help..
Hello there everyone,…happy holidays.
…I have 2 Keeppower 2600mAh (samsung cells) 18650’s, and they are being used in a zebralight SC600MkII L2.
now, when I charged these first time with the XTAR VP1, I did so at 0.5A, was that OK?.
and what is best for these now?. 0.25, 0.5, or 1A ?.
the flashlight will be using these batteries mostly in high mode.
thank you lots!. :santa:
avoid charging li-ion batteries faster than 1c (1x capacity - in your case 2.6amps) 0.7c or less is ideal
source : BU-808: How to Prolong Lithium-based Batteries - Battery University
so the bottom line - .5a or 1a is fine
personally i would use 0.5a if you have the time as it will probably cause less heat but thats just my personal opinion
Good Day ZebraStripes, :slight_smile:
I normally charge them at 0.5A, but if I am in a hurry then I charge them at 1.0A
If You charge them at a lower amperage (Amps), then the batteries will last longer….
Best Regards,
Roberta 0:)
PS:
A=Amps
thanks, i saw this post on a thread from cpf , a reply from HKJ states charging at 1A does not halve the charge time & increases wear and tear.
does that apply in the case of these 2600’s as well ?.
what do you say HKJ?.
thanks.
_
2600mAh cells are rated for higher charge current than the Panasonic 2900 and 3100 cells, i.e. you can use 1A charge rate without problems.
thanks, and if I do use 0.5, would that half the time compared to 1A?.
I mean some say if your in a rush use 1A.
does it make a difference 0.5 and 1A charging times?.
thanks very helpful HKJ!.
1A is considerable faster than 0.5A, but not half the time.
Looking at the curve below. The CC phase might be half the time, but the CV will be slightly longer, because the current has to drop from 1A, not 0.5A.
If you check my charger reviews, you will usual see I do one cell at different current, where you can get an idea about the different charge times.
HKJ, most of my cells are 3100 and 3400 Panasonic, what is the best charge rate for these cells. Mostly use the Xtar WP2 II chargers which will charge at .5, 1, or 2 amps. Asked the same question a while back and got a different answer from the the non-professionals, what does the expert say?
According to Panasonic
NCR18650A (3100mAh) charge rate: 0.885A
NCR18650B (3400mAh) charge rate: 1.625A
I usual uses 1A for both. If you have the time 0.5A will be slightly better for 3100mAh batteries.
would 0.5 be better for 2600 keeppowers too?. or best at 1A always?.
thanks.
0.5A is never worse than 1A charging, but any advantage will be minor (if existing at all) with a 2600mAh cell.
much thanks for all your helpful replies.
