Cheap button tops for your 18650 pulls
If you have a stack of 18650 cells pulled from laptop packs, you might need some of these.
The blue cell on the left is sporting the 5x2mm Brass Button from Mountain Electronics. $0.20 each. You can get them cheaper at Fasttech if you don’t mind waiting a month for delivery.
The orange cell in the center has a 4x1mm Raw Brass Tag from CLBeads at Etsy. Bag of 100 cost $3.10. It has a tiny off-center hole because it’s meant to be used for jewelry.
The green cell on the right has a 4x1.4mm Raw Brass Flat Round Spacer from CLBeads on Etsy. Bag of 100 costs $2.10. These have a tiny centered hole because these are also meant to be used in jewelry.
All three work just fine, but I like the shorter ones from CLBeads. They’re cheaper and don’t stick out so far. CLBeads, and many other Etsy sellers, have other shapes and sizes to chose from.
Nice. Brass beads is a good suggestion. Thanks for posting this.
Excellent post!
I have a bunch of laptop pull and been try to figure out how to modify them.
Thanks for the post and links. :beer:
Awesome!
I have 20 of those ones from FT, got another 30 inbound…they do VERY good for button tops, and are reusable :slight_smile:
I have a big tub of cheap radio shack solder flux, put a dab in the cup of the button, put a blob of solder on the iron, hold with needle nose tweezers, solder just sucks right in
I then take a rotary tool and a cylinder diamond bit, scuff the top of the flat top and immediately smear flux across it, flip over the button, hit it with the iron while holding with the tweezers centered, after a few seconds the button sinks down onto the flat top. Then I take a paper towel soaked with 91% rubbing alcohol and wipe down all the flux, it helps cool the button and battery quickly and gets the warm solder flux off the terminal easier.
The trick is to have a tiny blob of solder on the iron, it helps transfer the heat quickly to the button, using plenty of flux helps the solder quickly adhere and flow onto the battery terminal…gotta do it quick…don’t want to overheat the battery even though the terminal should be just a dome spot welded on the top, too much heat for a battery isn’t good for it (thus the quick rub down with rubbing alcohol infused paper towel for easy cleaning and rapid cooling)
Very good writeup and comparison :slight_smile:
Hmm, I have these in my cart http://goo.gl/1Yc3Kj
What about them? 6x1mm magnets. Maybe a blob of superglue under. The 2mm thickness might cause problems when run in series in a tube?
super glue can act as an insulator…soldering works but soldering those super magnets screws up it’s magnetism
well if you successfully solder it then the magnetism isn’t required anymore. Just becomes a metal disc. Works out to be 10c each.
My iron is only 45 watt, don’t know if that’s enough for the battery?
45w works, its enough heat to solder this beads, tried it 1min ago :slight_smile:
greets, bright
I have this in the mail for my unprotected Sanyo 14500. I’m not sure if they will work.
blob of solder on the top should also do it.
(covers any spot-welding-spots on pulls too)
Yep, I use good old 63/37 for my "buttons". It may surprise some of you, but I use laptop pulls for my work batteries, even though I have hundreds of high-performance 18650s sitting right in front of me. Why? Because they are cheap, I don't care if they have the highest performance (I'm generally only pulling around 1A from them,) and I actually use them enough to wear them out.
Now, in my high-performance lights, of course I use high-performance batteries. The voltage sag from most laptop pulls, even good ones, in the higher amp lights is much higher than fresh high drain cells. Last night my friend came over and we tested some freshly charged and freshly pulled Samsung 28A cells (2011 MFG) charged to 4.3v vs. a freshly charged Panasonic PF in his 4.5A XP-G2 triple. At the start, the output was nearly identical, but after 1 minute the 28A was already down almost 100 lumens to the PF. In a light running at lower amps, I'm guessing that the difference would be inconsequential.
Center the magnet on the flat top then super glue small bead around the magnets perimeter.
No insulation problem. Works like a charm.
