I bought some time ago this 3*AAA lantern
It had some bluish 5mm LEDs in it and was not bright at all.
This is a comparison with my BLF A8 on low, which was almost same brightness…
I liked the small lantern. So I disassembled the whole thing to improve it.
The LEDs were clamped in with a metal ring:
I removed the ring and then the “driver”, LEDs and reflector.
The driver was just a contact plate, all LEDs were parallel. The crappy switch and battery holder worked as resistor…
Stripped the LEDs…
I used a 4*7135 nanjg without voltage protection and two modes, high and ramping. Two parallel nichia 119 on a aludisc which I milled out with a dremel. I tried to cut down the reflector but it broke, also the heatsinking was suboptimal…
So I looked around for some additional heatsink…
Here we go I found some round alu ![]()
Grinded the ripples and sawed a ring with the correct height
Grinded to the correct diameter, removed the anodizing and “polished” it a bit…
I decided against the old contact board and used a copper ring soldered on the nanjg as contact. I glued the nanjg with some Fujik underneath the aludisc.
Here we have the new pill.
I removed the lantern anodizing, put some heatsink paste on the alu ring and hammered it inside the lantern.
Then reworked the copper contacts for the LEDs so that nothing can short, plastidiped the soldering and glued some pieces GITD foil on it. :bigsmile:
Some paste and in it goes…
I measured tailcapcurrent and got 1.4A, screwed tailcap down and it was less bright…
As I have seen almost every episode of monk I instantly knew the tailcap switch has to be the murderer…
I attached the tailcap to my power supply adjusted to 1.5A and I got 0.5V over the tailcap…so that thing has serious resistance.
I opened the switch and it is build really simple, just two plastic pieces and a spring, it is like a biro, but instead of the writing tip, a small round metal part is moved up and down to short the two outer metal parts.
I added a bit of solder to all contacting metal parts and some contact oil reassembled it and now I get 0.1V at 1.5A, I am okay with that.
Now I have a neat little lantern with useful and adjustable brightness, neutral tint and high cri.
