cheap p60 host modification
I have found a very nice host for p60 mods in a local shop.
It is a 14 led (bleee) flaslight that runs on 3xAAA. made of a solid piece of alluminium 4-5mm thick!
Somehow I heard him screaming; buy me, buy me! It was around 3 euros so I jumped to it.
At home first thing I did was taking it apart and putting in a XM-L dropin: It fits!!
my 3xAAA 's delivered 1.8A (tailcap)
Next on the list was putting a 18650 in the flashlight; This was a problem, the body is to short.
After replacing the clicky with a thinner one and a lot of work I managed to get a unprotected 18650 in.
(protected with tailcap and head loose).
I think I will stick with AAA's and a R5 dropin.
running with a protected 18650 head/tailcap loose
lightsabers are cool!
Good mod! Cograts!, looks alot better than the 3€ you paid for.
What the heck is that lightsabre? I'm not into starwars but i might have a use for that aynway, can you tell me more? It is laser based i guess?
I love it! Fantastic way to improve on a cheap light, Pipopopo. Although it looks like there's quite a bit of room around the drop-in which is leading to the reflector being off center on the lens. It might be worthwhile to visit the hardware store and see if there's a suitable piece of tubing that could help stiffen things up. Thick copper strips would be ideal and easy, but may be hard to find. Since you're sticking with an R5 heat shouldn't be an issue if you're @1A or so, so you may try soda can trick (Cut strips of aluminum from a soda can and wrap them around the drop-in). They should provide the stiffness with adequate heat sinking to center up the drop-in.
Again, good job and nice find on an inexpensive host!
-Match
Perhaps an 18500 would work a little better? Still a heckuva lot more capacity than three AAAs. Maybe even a 22600? Nice mod, BTW. Those 14 led lights are available here as well, but they'd be equivalent of 5 euros (I know, I know, terribly expensive)
Thanks all!
It is one of my Master Replica lightsabers (now produced by Hasbro) with led strips and motion sensitive humming/striking effects
I always fantasized of modding one into a flashlight.
As a matter of fact I have some copperfoil left but I will use it to cool my XM-L/sst- projects, so allu foil will have to do.
Although the Duraloops AAA run surprisingly well I think I might try a 18550
