You should compare it side-by-side with an aspheric light with a lens the same diameter as the reflector using same emitter and driver and see which is brighter!
It would be nice if someday, someone made a modernized better quality recoil thrower. I think the key would be to make the LED arm out of solid copper for much better heat transfer.
It would also be nice if it were made with 2 leds on the arm. A high-intensity one facing backwards for throw and a floody one facing fowards for close-range use as a mule.
