I keep getting asked about my bright flashlights, but when I tell them what they cost and that I built/modified most of them myself, I get weird looks.
So I search a budget set.. flashlight, battery, charger.
Something like P60, C8 or UF-2100. Shipping to Germany. Any good tips? I kinda lost overview over the real budget lights as I started buying more expensive ones. :)
I’ve given this some thought, if i were buying for someone i would get them a convoy M1 (T6 or U2), a couple of sanyo 2600mAh and a charger, i’ve been using one from intl outdoor, but there are many budget options available.
Under $35 all told
Those are some really nice suggestions, does anyone know about the drivers used? For example the Aurabuy C8 is very cheap, I wouldnt expect a Nanjg in them. Convoy flashlights certainly look nice too, is it safe to use unprotected cells in them?
Although I would prefer protected cells. Cheapest I found: http://www.fasttech.com/products/0/10001901/1143802-sanyo-ur18650f-18650-2600mah-protected-rechargeabl
The charger has EU plugs, but they are to short. You could not use them, Also the charger isn't really good. The Miller 101 could be nice (I have only the Miller 102, but this is out of stock since 2 weeks). If you want a charger with more slots buy two.
Most people have a charger with USB (mobile phone, navi) so it's also a good and small travel option. At home they can use their PC.
The Aurabuy C8 is good. Ok it has a XM-L T6 and not XM-L U2/3 or XM-L2 but think about it: The difference are only 100-150 lumens. If you don't use a LED flashlight before 800-900 lumens have a great WOW effect.
The Convoy C8 is great, if you want 3 mode (without blink).
I like my UF2100, I bought two years ago and use it often (I have the three mode - high, low,strobe). The 5 mode version is avialable for $12,69
I would not buy unprotected batteries for noobs. If the use the Nanjg with low voltage warning it's ok, but what happnes with the second flashlight they bought or a flashlight with serial connection?
A good solution are these protected Sanyo 2800mAh cells (2 cent cheaper as the 2600mAh, which isn't important, but 0,2mm shorter as the Sanoy 2600 and the cells inside are 2800mAh. You could not take a benefit of the 200mAh more, because they have to charged up to 4,3V, but if you charge a battery not every time up to 100% it's better for the battery life. If the charger would not stop completly at 4,2V and charge with a little mA and the protection also not stop it, you will not harm the batteries, if they are charged to 4,22 or 4,25V.
I don't think there's sanyo 2800 mAh cell. i recall only 2600, jump to 3100 and 3400 (with panasonic label, sanyo has been acquired by panasonic couple years back).
The default answer to the question is still: Sipik sk68. Get it to them with 2 14500's+charger and for months after they have been converted to flashaholicism they still find that their well thought over flashlight purchases are outperformed by their first Sipik . If they for some unlikely reason do not catch the fever it will still work on the odd alkaline lying around
A flood to throw is super cheap (like 7 bucks), and can use 3xAAAs. The neat things about it are the nice even floodlight which is great for a worklight… and ability to zoom it in to see the emitter and see stuff way off. Lightsaber effect.
For the super cheap price, I believe this is one of the easiest ways to impress someone…and you can even give em away for birthdays n stuff.
I really like the looks of the Convoy lights, they look decent made. I thought about the ML102, but it seems the ML101 is as good, just lacking the charging feature.
I equipped some people with the Convoy S2, ML101/102 and Sanyo 2600mAh protected and so far everyones been happy. Just thought I'd update this thread and ask if there are any new cool lights meant for starters? I guess a lot of people could use such a set. :)
