I recently got a SkyRay King and I would like to do 2 things that I have no idea how to do.
First, I would like to check the Current (Amps) that the light is putting out. (Using a DMM)
I know how to do this on a flashlight with a tail cap, but the SRK doesn't have a tailcap and it has 4 batteries.
Second, I want to figure out how to disassemble the SRK without destroying it.
I am unable to find any guides on how to take the light apart.
Could anyone help me out with how I would do either of these with the SkyRay King?
A good place to start. I’ll post some other links if I can find them.
The tailcap should turn off unless it is like one of mine and glued on. Once the tailcap is off remove 4 screws and try to float the board under the tailcap on it’s springs as you check current Place one lead against the SRK body and the other on the visible side of the board under the tailcap.
So far I've made it to page 7 of that thread. Very nice images.
If I feel confident enough to take mine apart, I might take some pictures of the process and post a guide for anyone else who wants to mod it.
(Any excuse to use my camera :P)
So it looks like after removing the Bezel, O-Ring and the lens then the Reflector should just unscrew and expose the 3 LEDs?
You will have to remove the one screw located under the driver board to remove the reflector. The reflector will drop out once the screw is removed. The driver board can be removed by inserting a harmless object into the switch hole lightly pushing on the backside of the driver board.
I’m a visual guy; I can’t wrap my head around this. :~
The way I found in one of the srk threads was to remove the tailcap and the contact plate. Then take 4x magnet and short heavy gauge wire assemblies, connect those 4 to a DMM lead and ground the other lead on the srk. I don’t have any extra heavy wire or magnets so I just left it alone. It’s ridiculously bright (running on Laptop pulls) and is on par with the 3up xml t6 that runs 7.2A on 4x IMR I received from OL, so I’m very happy.
The outer ring is threaded. It turns easily on most lights. If not you may need to make a tool that fits two of the holes and turn. Once you have the switch out then you will see the backside of the driver board. The front side of the driver board touches the + side of the batteries.
Needlenose or snap ring pliers in two of the little notches, then unscrew. The switch bezel captures the button. There's a little PCB underneath with the switch on it. Pull that PCB out (the wires are long and the excess is just stuffed inside) then reach in with whatever angled tool and pop the driver out.
He’s bridging the cells with copper strips to take the tail cap reading. Negative lead on top of that last copper strip, positive lead from your DMM on the bare aluminum where the pcb threads on, click the switch, bingo!
You can also put a penny on the back of each cell, then one more on top of the 4 pennies, if you don’t have copper strips. Get creative if you have to.
I taped 4 cells together and stood their positive end on the contact board of the head (body removed of course) and took the reading from those because my tail cap was glued on. Well, the one I was working on was glued on. And they don’t come off easily, let me tell you!
I just smacked my flashlight against my hand a few times and the button board popped out. It’s not held in by anything, it’s just sitting there. You might be able to pry it up with a toothpick or something similar
Getting the actual driver loose from the head was quite a challenge for me. I tried all manner of L shaped items, gently though. I was worried about damaging the components inside.
I eventually stopped being gentle, grabbed an L pick from the garage, wrapped the tip with tape so it didn’t stab through anything, and leveraged the crap out of it to the point where it felt like the tool was bending and the driver eventually popped out. The driver was extremely wedged in there.
i have checked the tail-cap amp draw by removing the four screws holding the back spring plate on, and using the DMM leads like in this pic. ( sample here was testing the low on a SRK 6T6.)
