Lexel
(Lexel)
9
You only need a ZWB2 filter if the LED produced white waste light which is interfering with UV output
Nichia LEDs are known to produce almost no visible light, just a bit of >380nm on the edge of spectrum is visible, a ZWB2 filter won’t help much here while reducing UV output quite a bit
if you want really invisible UV light you need a really good low bandwidth UV laser mirror that simply lets the unwanted light through building an angle light
if you look on filters they always got a wide range, so to pass at 365nm 80% they also pass like 10% of light you can see
a really expensive filter would blast budget but they are there
https://www.edmundoptics.de/document/download/359803
