If you’re feeling adventurous, you can even swap an S2+ with shorty tube, simple 1×– or 2×–7135 driver, and remove the switch (“rubber-boot” type, not the metal switch) and pack the boot with silicone to make it watertight, then run the wire directly to the driver, and out back to whatever battery pack you want with reverse-clicky switch.
Bap the switch to change modes. You can probably flash the driver (nanjg) with whatever firmware you want. Make it 20 brightness levels if you want.
There are a few headbands made for tubelights like the S2+. Go crazy…
