Stockton Flashlight
License
Flashlight design © 2015 Chris Luke. Flashlight documentation © 2015 Chris Luke.
This project is licensed with the CERN Open Hardware Licence v1.2.
You may redistribute and modify this project under the terms of the CERN OHL v.1.2. (Home · Wiki · Projects / CERN Open Hardware Licence · Open Hardware Repository). This project is distributed WITHOUT ANY EXPRESS OR IMPLIED WARRANTY, INCLUDING OF MERCHANTABILITY, SATISFACTORY QUALITY AND FITNESS FOR A PARTICULAR PURPOSE. Please see the CERN OHL v.1.2 for applicable Conditions.
Introduction
This project is intended to introduce some basic concepts of electronic and mechanical design. There is a small amount of soldering and a small amount of assembly. The result of this is a working and powerful flashlight.
The latest version of this documentation and of the Flashlight project is available at GitHub - stockton-stem/stockton-flashlight: The Stockton Flashlight Project or flashlight / flashlight · GitLab .
The design is not without flaws however, and deliberately so. As you build the flashlight you should pay attention to the steps and ask yourself how you might improve it.
Design
The project is centered on using a length of 1 inch Schedule 40 PVC pipe which has the desirable characteristic of its internal diameter being just a little greater than the diameter of ordinary “C” cell batteries. As part of the design we settled on using a small printed circuit board at each end of the tube to hold components, to hold the batteries in place and to make electrical contact with the batteries.
The primary element of the flashlight is its light source and we have selected an extremely bright LED (Cree® XLamp® ML-E). Whilst ideally suited for use in a flashlight, LEDs require some consideration; they must be soldered to a circuit board, powerful LEDs generate lots of heat and LEDs require some type of current limited to prevent them from burning out.
To limit the current supplied to the LED we use an inexpensive 350mA current regulator (ADDtek® AMC7135) that can operate on an input voltage of up to 6V.
Since LEDs tend to have a wide light distribution angle and for a flashlight we need a more focused beam, we use a curved reflector. The reflectors in this design are inexpensive plastic devices but are effective enough to provide very good value.
To hold the LED board and the reflector in place we use a simple 1 inch PVC coupler machined at one end with a large countersink tool to accept the reflector. Any such coupler will work but the female NPT coupler gives the flashlight a particularly rugged look. The positive (+) terminal of the batteries makes direct contact with the underside of the LED circuit board.
The other end of the flashlight has a copper spring soldered to a circuit board to make contact with, and push against, the negative (-) terminal of the batteries. On the opposite side of this board there is a simple pushbutton toggle switch to turn the flashlight on and off.
To secure this board to the flashlight, and to enable removal to change batteries, two solder lugs are screwed to the side of the body and their ends soldered to the board.
To provide an electrical connection between the two boards we use self- adhesive copper tape which runs along the inside of the PVC tube. It makes contact with the LED board using plated pads on the underside of the board. The button board contacts the tape using the solder lugs used to hold the board in place
