Could I use vodka? Just want to check its safe for the dome and pure enough. Don’t have any isopropyl alcohol or everclear 190 proof.
Its a new XPG2 led right out of the package that had a black spot. Would not just wipe off. I know I should have went for something other then hand sanitizer but I figured I’d clean any moisturizer left over with warm water. :~ Now I’m worried simple water isn’t enough and would like to be sure no oils are left that could burn on.
Wait... you are not talking about cleaning after a dedome, aren't you?
If you have just to clean the dome from dirt, any kind of non-agressive lens cleaner would do it ok. Like you were to clean camera lens or eye glasses.
The dome is not that susceptible, even a water moisted cotton pick is ok to clean some fingerprints or debris.
Just be carefull and soft, don't push hard at all. Just soft swipe.
