Color variance in same tint bin (3C)
I’m sure I am not the first to observe this, but in the last 2 months I purchased three XPG2 R5 3C from Mtn Electrronics. One of them has a lovely neutral tint while the other 2 seem a bit more cool. I’m not really complaining just a little dissapointed because when I bought the last one I was really hoping it would look more like the one I really love. Im not sure where RMM get his supply but i wonder if they are perhaps mislabeled. I understand there is variance within tint bins. Have any you experienced this as well?
Yes tint variation even within a single bin such as 3C can be quite obvious to the eye. Particularly if you compare them side by side.
If you study the ansi chart of cree binning you’ll see that 3C is actually quite a large bin area. So a 3C emitter can actually range anywhere from about 4800k to 5500k in temperature and from fairly balanced and more rosy tint near the BB line to a rather obvious green/yellow tint.
Here’s a saturation boosted shot of a light that contains 5x XML 3C emitters. The sat is upped to exaggerate the differences of the tints but those differences where readily apparent to the eye by looking at each emitter output separately.
In my experience they tend to be more on the green side on average but maybe the one you like is an exceptional sample that’s on the far right of the 3C bin but also near the BB line giving it a nice neutral tint combination.
Of course there is a possibility that the emitter is mislabeled but you’d only really be able to know that if you get a bunch of 3A or 3B emitters to compare against. And unless you get a large enough sample size it’s very likely that you could be comparing two emitters that are…
A: Seperated into two bins even though they are both actually very near the division line between the two bins. Two emitters, one classed as 3B or 3A and the other as 3C could look basically identical if they are not far apart on the spectrum.
B: Comparing two emitters from the very furthest apart range of the tint bins. Which would give you an exaggerated idea of the difference between the average 3B and 3C tints.
Basically it comes down to being a crap shoot, and unless you test and evaluate dozens of emitters you won’t really know what to expect from the average 3C. :slight_smile:
A reason why I like the mt-g2 2step/4step macadam (easywhite) binning. It’s a much tighter classification and results in a more predictable result.
Thanks for the picture example. It would be nice if the bins were more tightly contolled like with the MTG2 LEDs.
I have few lights with a perfect tint.
I own still fewer lights with the perfect beam profile .
The lights that have both are treasured indeed .
It’s even worse if you get E-3 classification as it includes all 4 - 3(A,B,C,D).
