COMCROSFLY. Layman impressions.
What?. What kind of a name is that?.
Forget the name. It’s an inexpensive 26650 3k lumens light.
I compared it to the Fitorch P25 with the 26650 extension,
and it has the same amount of light. And a few advantages:
It’s diffused. The head is bigger. It’s smaller in size. It’s cheaper.
It’s three emitters and turbo lasts longer.
Will it last?. Dunno. So far so good. Besides the vendor is Amazon.
Easily replaced or returned. All that wonder for 23 bucks.
Ain’t this a BudgeLight flashlight?
Cheers.
Link?
https://www.amazon.com/Flashlight-Rechargeable-Waterproof-Best-Camping-Emergency/dp/B07ZFC3JQF/ref=sr_1_2?crid=1RHYCFTAMXUSF&keywords=ComCROSfly+flashlight&qid=1642689868&sprefix=comcrosfly+flashlight%2Caps%2C81&sr=8-2
Sorry for the long link. Dunno computers. Neither flashlights, hehe.
I think it will be easier to type Comcrosfly in Amazon.
Cheers.
BTW, I also got the ugly blue 26650. I dunno if it’s included now.
The first 26650 with Tip I’ve seen as standard equipment.
It’s way taller than the Keepower IMR that is sporting now.
But any flattop 26650 will do. Springs suffer less.
The most appropriate would be the Liitokala 26650 5000mAh.
I paid 40 bucks for 10 of ’em. Cheap to cheap.
I’m sure I’ll find some use for the blue tipped one.
Also, bear in mind that turbo is pressing for a while.
From any position. Even off.
Cheers.
Not familiar with these P9 but funwok has a lead (link) and the spec sheet would be a 3535 footprint LED non-isolated at ~500 lumens output (3 Amps).
Using shorthand terminology is usually a clone or cheaper version of a popular make. So this light wouldn’t make more than 1500 lumens. And certainly be in the higher temps (6500º). If the strobe is hidden (double click) it may be a nice find.
As for your cells, be careful as there are many counterfeits. Although they may perform adequately they don’t have the stated capacity nor the current capability of the originals.
Edit: here’s the product sheet link
And you can download the datasheet from there.
A picture so we know what this is about.
I bought one of these lights —Not bad but the P9 LEDs are pretty bad — The UI is 3 modes but if you pause in any mode the next click is off — Hold Turbo on then can only go to off from Turbo —— Turbo starts ramping down immediately and stops some where around 1600 lumens — surprising the included cell tested 5240 mah and is high drain
I bought it with full intention of modding — the MCPCB is oddball 28mm (aluminum) — The Angie and Cute lens fit but the reflector part hits —I was able to file a 32mm board down and make a Angie lens work —now it’s a quad Samsung 4000k tint
Click and hold UI. Surprising this fellow can deliver higher than 1500 lums. Usually overrated.
Nice that you were able to correct the emitters. Why didn’t you just not reflow new Sams?
EDIT: BTW what’s the difference between the ANGIE and the CUTE lens?
Reflow was my intention, but the stock board was Aluminum — Angie is a quad (clear spot ) —Cute is a triple (textured) — I used the quad because the depth was the same — I was just thinking that I never compared the stock lens to the copper board triple I had
Surprising the stock P9 LEDs with a VTC5A cell did 3300 lumens ( starts ramping down immediately- lots of lights do this now a days )
The P9 LEDs at 3300 lumens are washed out compared to other triples around 2000 lumens ( SST, Samsung, Etc )
So many LEDiLs that I’ve gotten lost. So thanks for the difference.
So I take it you kept the stock driver? If I get this right, click and hold for turbo, next click OFF; click for ON and would click for OFF. The modes are auto-stepped – high to low or vice versa?
This could be a nice modder light, price is fair and if the construction is good. And as you said, filing down a 32mm MCPCB is doable. (I’m looking at not much wattage, so aluminum would be ok). If the Ui sucks, what size driver?
You bought an older version.
Mine goes to turbo in any mode if you just hold the switch.
And, yes it has a strobe. Double clicking.
If this one is overrated. so is the Fitorch.
Besides, if I want power on this size, I have the Imalent R30.
But it’s not 23 bucks.
Cheers.
Mine goes to Turbo from any place —just hold —- but goes to off afterwards — UI is low-med-high hold for Turbo double click strobe — with the P9s it draws about 14.4 amps on turbo —high is close to 5 amps —- slightly less with the Samsungs —- surprisingly it handles heat very well
I bought this light as a quick mod for the Ledil lens I already had —- Quickly it turned into a lot more work than I wanted to do — total now I have around $48 in the light —-
Nice contender for “little (extended) fatty” but checking Amazon.ca it comes to $80
Coming full circle with OP, I don’t shop much Amazon as the Canadian prices aren’t always good.
Bummer!
