I have immersed myself in learning both the D3AA UI and the Zebra UI. Both required extensive use of charts and reading manuals. Both seemed really confusing at first.
I believe I now have a good grasp of both UI options and for me, Anduril is much easier to use.
Last night I was carrying the Zebra, when my cat came in and released a cricket in the living room. I clicked the Zebra On, and the result was brighter than I wanted… So I had to start thinking about which clic sequence would give me a slightly dimmer output… After a few moments fiddling with different button clics… I got the output I wanted. But, it was not as intuitive, for me, as my D3AA.
So I put the Zebra down and reached for the D3AA. For me, it is much easier to use Anduril UI. I can increase or decrease brightness without thinking through multiple separate clics to find the output I want.
For me the Zebra requires a lot of thinking, and I have to remember how it is programmed. The Zebra also produces undesirable outputs and flashes. A Zebra will preflash the 1C ouput when I use 2C from Off (no matter what outputs are programmed into those clics). It also preflashes the Hold output when I use 1C. And I often get the 1C output, when I actually want the Hold output. Also, if my Zebra turns on at an output that is too bright, when I do 2C from on without waiting long enough, it gives me Strobe.
With Anduril, I never get Strobe by mistake, never get High output when I want moonlight… For me, the D3AA UI is much more predictable, and requires much less forethought than the Zebra UI. IF I was to hand a light to an untrained operator, it would be easier for me to explain how to operate my D3AA than my Zebra.
otoh, I much prefer the Zebra host, it is smoother, more balanced, and more ergonomic. The D3AA has an awkward oversized head shape, that is not smooth.
Ergonomically, the Zebra is much nicer, and it has a much better pocket clip. I dislike the D3AA pocket clip so much, that I just dont use it at all. otoh, if I take the clip off the Zebra, Im left with some sharp corners that I dislike, on the clip pedestal… So I dont really like using the Zebra without its clip… But I also dislike using the clip, the tip of the clip sits under my support finger when I press the button… The Zebra clip is very good for retention, but not so good for handfeel.
One other difference between the D3AA and the SC54c N, is the beam… The Zebra has a nice hotspot plus spill… it throws better outdoors than the very floody D3AA w standard 10511 optic. otoh, at close range the D3AA produces a nice even field of illumination… while the Zebra hotspot tends to produce more glare. When I use a light with a hotspot at close range, I often have to wave the beam around to find the right intensity, usually near the corona of the hotspot… With the floody D3AA beam… I dont have to wave the light around as much, as the field of illumination is relatively consistent in brightness.
One other difference is that the D3AA is a true dual fuel AA/14500 light… The Zebra is AA only…
I usually use my D3AA in smooth ramping mode. otoh, I have programmed the stepped ramp to 12 steps (homage Zebra)… With the D3AA in stepped mode, I can ramp up and down through all 12 steps, and it will remember whichever step I turned off at. The Zebra can not access all 12 of its internal outputs sequentially, and it can only access any 6 modes, without further programming… The Zebra UI is relatively clumsy, compared to Anduril.
