Comparing some 16340 with built in USB C ports
Got some USB C 16340 recently and thought I’d measure their lengths since not all CR123/16340 lights can accommodate protected/longer cells.
950mAh Nitecore 16340 (36.0mm)
800mAh Fenix 16340 (34.8mm)
900mAh Xtar 16340 (34.3mm)
800mAh Wurkkos 16340 (33.1mm)
For example the Wurkkos DL04 can only use Wurkkos and Xtar cells, Nitecore and Fenix cells are too long and the light can’t turn on (twist to turn on).
Nitecore and Fenix seem to charge quicker, but they cost more.
5.0V 1.0A Nitecore 16340
5.0V 0.5A Fenix 16340
5.0V 0.4A Xtar 16340
5.0V 0.4A Wurkkos 16340
Uhh… You’re using Kapton tape on one or both of the terminals before you’re using a conductive caliper to measure the length… Right…?
Secondly, for the rate of charge, were all cells equally empty prior to charging? The CC/CV algorithm means the current drops as full charge approaches.
Caliper is plastic, no need to waste precious Kapton tape!
The cells were all around 3.6~7V from the package when I plugged them in.
WB, yclo!
Thank you for the excellent info!
I made the mistake of buying the Vapcell 16340 w USB-C and it is too long to work in my lights. I should have read the length specifications before wasting my money.
I needed to replace the Olight 16340 w micro USB that was 34.5mm
Very helpful that you posted length measurements, they show that the Wurkkos and Xtar 16340 w USB-C would work in my lights.. The Fenix maybe would too.
