Considering DW4 Mule mod - any gotchas?
I have an Emisar DW4 that I don’t use often because it has Osram W1 Amber emitters. It’s cosmetically a little rough, so not worth trying to sell and buy something else. I’m thinking of ordering an 8x MCPCB from Hank and soldering it in with no optic to make an FFL351A mule.
Besides the MCPCB and emitters, is there anything else I would need for this mod? An o-ring or washer to hold the glass lens up in the absence of the TIR optic?
Alternatively, I could stick with the standard 4x MCPCB and use the new emitters with a zhu hybrid mule optic. In theory, this approach would retain the aux LEDs, though keeping them all intact while reflowing could be tricky. Also, I’m assuming Hank uses the same boards for W1s as for 3535 emitters but that may or may not be the case.
Would be interested to hear any thoughts on how I should approach this.
Edit: I failed to consider the driver setup - As I understand, since this light is boost driven I will have to stick with the 4x MCPCB so the emitters will be wired in series. Will probably opt for the ZHU hybrid optic instead of a spacer, since I already have the former on hand. Only remaining question is, does Hank ship W1 lights with a special MCPCB that I will need to replace in order to get the FFL351As to fit?
I have this setup in my D4V2 with FFL351RD’s in a mix of 6500k and 3700k. It comes out to 5000k with CRI of 98 and Zhu optics. Pure floody, beautiful, white light!
That looks really nice!
