Quote: Im trying to get a coupon for HL50, which should be better than the HL21?
Not necessarily. It depends on what you want from a lamp. Better or worse are not the right way to look at it. The question should not be “What is the best headlamp?”. The question should be “What headlamp best fulfils my needs”. So first you need to back up a few steps and ask “What are my needs?”.
All other things being equal, for a given battery, a narrower beam will let you see further, but you will see less of what is off to the side. A narrow beam = long throw (beam range). The other way to get more throw (or more flood for that matter) is to chuck more electricity into the emitter (LED), but this will drain your batteries faster. So it is a three way trade-off between beam range, beam width, and battery life.
On the maximum brightness setting the HL50 chucks out 170 lumens, yet only throws to 77m (with a 3V CR123ALithium battery, less with an NiMH). The HL21 only puts out 97 lumens, but throws much further, out to 93m.
So what is happening with those extra 73 lumens that the HL50 puts out? Well for a start they are running your battery down faster, and as the light is not going towards greater throw, it must be going into a brighter or wider side spill. But is it better or worse? That depends on whether you need beam range, or a wide bright spill.
If I am searching for a cabin, or trying to find that safe rout up the cliff, then I want lots of throw, and then some more throw, and I don’t care about the spill. On the other hand, there is no denying that a flood beam with little or no hot spot is much more pleasant when ambling along on a well marked trail, setting up a tent, or reading a book.
Long throw means safety, and less backtracking because you went the wrong way. But more floody is more pleasant on the eyes, and more useful in situations where you don’t need to see far, like erecting a tent. The HL21 has a very throwy beam, which is not to everyone’s taste. But it also has the flip-up diffuser that that turns it into a flood light, so you have the choice at your fingertips.
Here is a little talked about fact. If you are walking through trees and have a mixed beam with a central hot spot, and a bright spill, even though the beam contains a long throwing hot spot, the bright spill is going to bounce of the nearby trees and cause your pupils to contract, which means you will not be able to see as far as if the spill were not so bright.
I like the spill to be bright enough to clearly see where I am going to plant my next steps, but no brighter.
Personally there is no way that I would trade my Fenix HL21 for the Fenix HL50. For me the HL21 fulfils my needs much better. But that does not necessarily mean the HL21 is the best light for you, or that it is “better” than the HL50. I highly recommend the HL21, but you will have to decide for yourself, which lamp best fills your needs.
