Convoy C8 Host Discontinued?
I saw Simon does not list the host anymore… FastTech shows it as being discontinued. Why? When will we see all the other hosts disappear…?
That is the old design with the removable pill. The new one has an integrated pill.
Ok, might be… Thought that FastTech would have just updated that stock item with the latest version.
The new one is not as easy to mod so they might not carry it as a host.
I presume you’re talking about the integrated pill? If so, the same has to go for the M1 & M2 hosts? They’re still available?
The new model is available via Mountain.
Yes I am. The M1 looks like the old one but the M2 looks like the new one.
S3 is the most difficult imo... unless you do not mind long wires.
Ive placed my order :wink:
I agree… I’m not happy with the integrated shelf on my S3. I was disappointed as I was expecting the brass thread-in pill when I first ordered, as I had intended to solder a spacer directly to the pill for triple-use. :_(
I still use it, but for a lower-powered triple instead. I just received the S6 to use for my triple XP-L HI build…
I hate the integrated C8 pill… almost impossible to get a good XP-G tight spot on it now without a lot of work. Figures that they would go and screw it up as soon as it got to be just about perfect.
Herewith feedback from Simon…
“new version host will be uploaded in the future”
I presume he’s talking about the matt black, integrated pill version. Was wondering if there’s another ‘New’ version… Not sure why they did not just update the details / specifications of the old listed host. Anyway, seems it will still be available.
Hi calan
I have not yet modded the new version C8. Whats the issue with the focus? Is the pill area mounted to deep in the light, thus, when you tighten the bezel the reflector sits loose?
Thanks
There’s always the ThorFire C8. I haven’t seen it as a host so you’d have to buy a complete light.
That’s parts of it; I had to sand the bezel to get the reflector and lens to tighten.
A bigger issue (for me anyway) is that I can no longer use the nice XP-G reflectors and centering rings with it. With the threaded pill, you could use those slightly shorter reflectors and simply back the pill out against them for a nice tight focus on long throwing XP-G emitters…which is what the C8 really excels at.
Now we are limited to one reflector, and the only way to get an XP-G to sit deep enough into it for a perfect focus is to space the PCB off the integrated deck, and then fight to get it focused with the large XM-L centering ring.
Mmm, ok thanks calan.
You’re kind of implying that your mod adds extra height which causes the bezel not to tighten down. That’s a big issue. I’m planning on using the standard SMO reflector, which makes things better for me - I believe its very good reflector. I’m planning to fit a noctigon and possibly modify (sand down) the standard LED spacer for better focus. Also planning on using using XP-L Hi and gluing the LED spacer to the noctigon for easy LED centering and assembly. Will make use of FastTech’s AR lenses. They claim the lense is 1.5mm thick. How thick is the standard lens on the new host?
With this setup extra height might be added via the noctigon & AR lens. Possible sanding down of the LED spacer might take away some height. Mmm, I’m worried I’m having issues with this host. I’ve ordered quite a few from Richard.
No, the bezel would tighten, but not trap the reflector and lens…so they were loose. The only way to fix it (without finding a different o-ring) was to sand down the bezel so that it hit the reflector/lens before it bottomed out. And that was with a standard XM-L emitter on noctigon and the centering ring that came with it.
My wanting to use that host for an XP-G emitter is a whole other PITA.
Hi Calan, sorry my bad, I see… This is not good. I’ll chat to Richard, my order has not shipped yet.
This implies the standard ALU mcpcb is thicker than the Noctigon…
Possibly… or I just got a quirky host.
Either way, there sure isn’t much wiggle room there. I don’t like the idea that I’m putting a light together that may or may not require a trip to the belt sander. :slight_smile:
A thicker o-ring and/or lens would help, but still… we shouldn’t have to go buy replacement parts to make a host go together reliably. I really, REALLY wish Simon would have left it alone once he got to version 2.
