sorry to bother you guys again.i have got a new xml warm led for my convoy c8,is there any way I can get a better throw.it is the old type c8.is the warm the better one.
Is that emitter an XM-L or XM-L2? An XM-L2 would be higher output, giving you more throw.
Warm tints sacrifice total output to obtain the warmer tint. Cooler white tints tend to have higher output, and would give you a better throw. A 1A tint XM-L2 would be throwier, and would appear brighter to your eyes due to the cooler tint.
Alternatively, you could use a XP-L HI to get even more throw. An emitter with a smaller die (XP-G2) would give you a smaller hotspot with less spill, without sacrificing hotspot intensity.
Finally, what driver are you using? It should be 3+ Amps to get decent throw.
just an xml.so not very good then is it.where is best place to get a better one for the old c8.sorry don’t know what driver is in it.how can I tell.
Can you post a picture of the spring side of the driver? Dedoming will give more throw but make the warm tint even warmer. Typically one starts with a 1A tint so it starts with higher output and the tint shift is to neutral. Member 3tronics has a store in the UK and can help you out. An led swap to XPL HI or XPG-2 would also improve throw at any driver current.
would a xpl hi and fet driver give me better throw.
If properly centered and focused in the reflector, and if the emitter is mounted on a direct thermal path star, like a Noctogon, then yes, you should see a significant improvement in throw.
Beamshots with Stock XPL Hi C8
do you know where I can get them from.cant find any.
could I dedome the one I have in it to make it throw more
Yes
A copper star would help deal with the heat better at high output than an aluminum one
That board is not good as its not DTP and not copper, you will loose lumens or the LED get cooked
Best is a DTP board where there is no insulation layer between the middle pad and the heatsink, an aluminium DTP board would work better than standard copper but are not common
Get LEDs here for example nice tints on noctigon copper DTP board
http://intl-outdoor.com/noctigon-xp16-v2-mcpcb-cree-xpl-v6-3d-led-p-812.html
A good fet driver is also on that site availiable or the BLF A6 one
if I get the xpl hi v2 1a from fastech will I have to centre it and focus it or can I just screw it down and it would be ok.
Screw it down and glue the old centering washer on the MCPCB so that the XPL is centered
i have a convoy c8 with the xp-l hi and it’s spot is noticeably tighter than the xml2. screwing it down doesn’t center it… you have to center the reflector. i got one from mtn on copper and running it around 5amps…. the c8 handles heat pretty well
My newer model C8 with the XP-L had the little plastic spacer that fit around the emitter so centering was easy. It has the tightest beam of any of my lights but I can’t decide if pushing closer
to 4A would even be worth it. It’s a quality light as-is like all Convoys but I can’t decide if I want to
leave the emitter and drive it harder to make it a pretty good thrower or just swap it with an XHP-70 so the spill is more suitable.
I tried dedoming my xmj last night and now it doesn’t work. I have got the plastic ring on mine as well. The one that goes around the led. What is delivery charges for led from aliexpress to uk. Or any suggestions where to get a xpl hi from. Don’t tell u a lot on there in English.
3tronics is also a member here and local for you, he should have the stuff you need. If it’s not listed on his site just contact him.
there are many AE shops without delivery charges, some item descriptions don’t have a lot of information but the title has all the information needed (bin, tint, type,…)
