I’ve been considering this light as it doesn’t seem too big for a 21700 battery light, however, I am wondering if a Vapecell F63 would work good with this.
The Led it uses is the Seoul CUN66A1G and the driver is a buck/boost, which will lead it to having a max amp draw of 3.
I’m wondering if the high capacity wont make too much of a difference, and if I should go with a Cell that has a bit less mAh.
Also, if there is a similar sized flashlight that has better heat dissipation than the s12, let me know!
Thanks
