I need some help please as i have broken my very first flashlight.
I ordered a striped lens with my convoy s2+. As i was opening the brass pill it was very very tight to initially turn. I finally managed to get it undone and replaced the lens. Now it wont switch on? When i unscrew it and its right at the end of the thread the flashlight illuminates if you hold it at an angle. i have added some pictures of the pill showing various angles. Can anyone spot anything?
Did you screw the silver (non-anodized) end into the head of the light? If not, that’s the end that needs to be in the head to make the connection right. Also, make sure your reflector isn’t shorting out on a solder joint.
Photobucket sucks for posting pictures. Try using imgur.com or SLi.mg. Upload your pict, copy and paste the direct url to the “insert image” function here, resize it to 60 or 70%, done
Well, the 2988 × 5312 (9:16) overwhelmingly bigass picture can be seen, though it still seems to have a bug in its name, as it ends in "[/img]". I recommend resizing the image to some sort of manageable on-screen size (like 540 × 960, 576 × 1024, resize to 100%, etc). Using a lower resolution makes the page more manageable for low screen resolution devices, yet one can still view the full image by opening it in a new window.
Edit:
Oh, well, seems to be fixed now, my friend just got me distracted a good little while.
Mmm, time for a related question, now that this topic's hot.
Would it work right to use one of those dual sided Nangj 105x drivers rearranging the chips stacked on one side so as to use the host driver's retaining ring?
What really pisses me off about some of the places that sell Convoy S2+s is that they don’t use a retaining ring for the driver…they solder it to the pill. I can understand that if there’s no threads for a retaining ring but there’s clearly freaking threads there!!! :rage:
The batteries are protected. I ordered two convoy s2+ at the same time from Simon.
I did check the soldering but it looks ok to my untrained eye?
I tried the old lens then the new one etc, tried it all but it would not work. On/Off switch was not touched.
Like i mentioned previously, when your on the last thread when unscrewing the head, if you push the head at an angle it will come on. As soon as you let go or screw it back in, it will stop working.
Is it the reflector your referring to? Yes, i compared everything with the spare convoy i have. Cant seem to figure out whats up with it.
What i will do when i get home is replace the entire setup in the pictures above into my other s2 and put that into this. Then i will for myself anyway narrowed it down to if its the above in the pictures or something else?
I’ve had multiple problems with the couple of 3rd-party “bargain” S2+ lights I bought, and eventually warmed up and sucked out the solder, cleaned out the pills completely, and put in retaining rings. It’s hardly worth all the trouble.
You can ask Simon to sell you some extra pills — with retaining rings! — the next time you order something directly from him.
I’d bet the solder is the problem. Where did you get this S2+, and did you do anything to it after you bought it?
Twisting the pill bends anything loose — solder or under the driver board or spring.
Screwing the pill down tight pushes on the spring and can push the driver away from the lumps of solder.
Or the wires soldered to the driver on the inside of the pill could be poorly done.
Testing the light engine outside the light will tell the main story. If it works with a cell directly connected to the light engine (ie: positive battery contact on the spring with a wire connecting the negative end to the brass pill) then you know the light isn’t going together properly. Either the battery tube has ano on the very end, it’s reversed (anodized tail end put in the head) or the solder is not making good contact between the driver/pill/battery tube.
Also, if your new lens is thinner than the stock one the pill may screw in further and cause a gap between the end of the battery tube and the pill. A copper wire can be made into a circle and laid in on top of the pill/driver to breach this gap. I’ve used a copper core wire from a TV cable, or a 12ga wire from house Romex, either will work, one is thinner than the other.
Edit: Bare wire, of course. A ring can even be made from a paper clip but I prefer to use copper so as not to introduce resistance in the circuit.
If that lights up, then move the wire from the brass pill to the solder blobs and negative ring on the driver itself.
Then press gently on it and see if there’s a failure of the connection between the driver and the pill — like the solder blobs lifting off the brass, which happens a lot.
