Convoy S2+ slooooow memory
I’ve just bought an S2+ with the 12 group 5A buck driver, running it in group 10 (1, 10, 35, 100) and with memory turned off. So far so good. However the light needs to be off for ten seconds before it will reset to low mode, switching back on within ten seconds results in it advancing to the next mode. My S6 (with the same 12 group 5A driver) and two T3s only need to be off for 2-3 seconds so this seems like a really long time.
Is this normal for an S2+? If not, is it something I should speak to Simon about? It’s probably not a problem in real use, but if it’s not working as it should I’m slightly worried that it might go wrong.
check that the retaining rings (switch and driver) are tight
Just checked, yes they are.
I have also cleaned the threads and the ends of the tube in case it was stray lube causing a problem.
Does this S2+ have an illuminated tailcap?
No, standard black rubber button.
Has the driver (including spring) been soldered or manipulated (heat, solder, etc) by you after the flashlight arrived? Or did it arrived like this, stock?
If the later, maybe it is a faulty component or something :x:
EDIT: Also, have you been using (very) high drain batteries or let the flashlight ON for a long period?
have you tried opening it? Maybe it’s a bad contact on the switch or they installed a LED switch…
No, it arrived like this. I was initially thinking that it was impossible to switch off mode memory because my usual half-press for three seconds didn’t go back to low mode. It was only after a couple of tries that I realised that the mode was actually advancing.
The battery is a Sanyo NCR18650GA, 3500mah, 10A discharge. It has not been on for more than a couple of minutes at a time as it’s not getting dark until late here at the moment, so it’s only been played with.
I’ve only tried opening it in so far as I’ve taken the caps off both ends and tested that the retaining rings were screwed tight as suggested earlier. I have also cleaned the threads and the end of the tube but that’s all I’ve done.
Since you’re using the stock switch.
The only thing I can think of, is the Off Time Capacitor on the driver is the issue and it’s not decaying fast enough.
I asked about the illuminated tailcap because I’ve seen it cause issue with the Off Time Capacitor Decay Rate.
Your explanation about the off time capacitor sounds right to me. I’ve sent Simon an email explaining the symptoms and asking if he can help. It may be a minor thing but it is bothersome when it doesn’t behave the same way as my other Convoy clicky lights.
Other than that minor issue, I really like it!
Does it have the same issue with the other groups? Probably does, but just curious.
It does. I think it was in group one when it arrived because it had the blinkies as part of the modes which really didn’t make disabling memory any easier.
Simon is sending a replacement. :slight_smile:
