Convoy S2+ XM-L2 Build
[reserved] Will post pictures as build progresses.
Grey Convoy S2+
Ask away - I'll help with what I can and I'm sure others will too Smile. I've worked on a couple S2's/S2+'s, S3's, many other EDC's - triples, TIR optics, or straight setups.
Put a triple in it or throw it away!
Maybe you are dealing with a S2 and a S2+?
I recognise the large pill and the short reflector as the ones that came in my S2+.
I’ve read somewhere that the S2 has a smaller pill and a long reflector.
Combined (large pill+short refl. versus small pill+long refl.) they are +/- same size.
I drive thru Patchogue every day to/from work on Sunrise Hwy! A friend at work lives in Patchogue, lake-side.
Yes - probably S2 vs. S2+. There's been some variations out there - 2 kinds of S2+'s even - the red one is unique right now with having the SS switch button.
For the LED wires, what I do (maybe not everyone) is keep the wires as short as possible. I mount the driver, or at least get it into it's position, then trim the LED wires to fit to the + and - pads. So, the last thing I do in assembling the pill is solder the LED wire leads - this makes them the shortest possible length -- least possible resistance. This means when you take the pill apart in the future, you must de-solder the LED wires first before removing the driver. Most stock lights are not like this - they have extra length wire coiled up in the pill, but stock wires are usually 28 or 30 AWG while I use 24, 22, or 20 AWG, depending on what I fit. Generally, I'm using 22 AWG wires.
I dunno for sure, but I think most modders do it this way. 22 AWG coiled up in the pill may not fit anyway, depending on the space you got.
For a triple in a S3 (old S3, not S3+), what I did was buy one of RMM's S2 spacers (here), and sanded it down to the height needed for the S3. Got to do some careful measurements, and of course a belt or disc bench sander helps big time. I used the disc sander for mine (harborfreight.com/4-inch-x-36-inch-belt-6-inch-disc-sander). There other methods I'm sure, but I'm limited what I can do, machining wise, in both equipment and know-how.
The S3 used to be by favorite EDC tube light before the RED S2+.
Sorry, my bad, will delete my posts.
Maybe the mod can clean it better.
Don't worry, we never stay on topic - think the most useful info posted is usually "off topic" Smile. No strict enforcements here, we got a great mod Wink.
So parts came in Today from M.E
XM-L2 T6 4C
3.04A guppy qlite driver
Uh oh, the holes on the pill are not drilled right, thats Okay i will fix that
oh yea the XHP70 in the background will be getting built today too in a whole other thread later
Hello TIR & glow, good bye Reflector.
Looks great? Which TIR is that? Is it the one from Fasttech?
I'd like to know as well.
Yes it's from FT
got a link to that TIR?
http://lmgtfy.com/?q=Fasttech+20mm+tir
What was that you taped on? Was that just glow in the dark tape used as an insulator?
There GITD disc from James3
Nice.
thanks richard
