Convoy S2 - XPL HI - Fast Overheat Issues
Hi All,
Built an S2 last night, with the following:
- S2 Host
- XPL-HI
- INR18650 - 35E
  • Convoy SST-40 Driver - 17mm - (From Simon’s store)- said to have ramping
I thought that the low discharge rate of the battery along with what I was told would be a max of 6-8A current from the driver that it would be okay, but I’m facing the following issues:
- LED goes from its warm 3000k to cold blue within about two seconds of turning on
  • No mode changes available despite trying to abide by what is stated in the driver’s description on AliExp.
Anyone have any tips? Is there still too much current running through the LED or is there faulty wiring that I wasn’t aware of? Nothing seems to be shorting but I was hoping someone could propose some other issues that I wasn’t aware of.
Thanks all!
XPL HI is usually very tolerant of high current. Some things to check:
  • Are you using a direct copper star?
  • Is there thermal paste under the star?
  • Maybe try reflowing the LED on the star. Perhaps the original reflow wasn’t done properly with no solder under the thermal pad for instance.
Yes.
Did you put thermal paste on it?
WOW WHAT A TESTIMONY FOR COPPER STARS
I believe that’s it thanks so much guys - I ended up using an aluminum one I had laying around but I guess it’s time to delve into my stash of MTN DTP stars.
With that topic in mind, what is then an appropriate application for NON copper MCPCBs? Low-current LEDs?
Thanks so much for the fast troubleshoot, gang. Really appreciated!
Oh that was it then.
Put the LED onto a DTP MCPCB then.
And yes, low current LEDs.
Aluminium MCPCBs start to falter behind at about 2A with 3V LEDs.
Aluminum non-DTP MCPCBs seem to work OK at about 3A, which is what higher-powered 3535 LEDs (XP-L, SST-20, LH351D) are rated for. Once you start overdriving LEDs, you need more, and copper DTP should be sufficient.
DTP Copper stars are so cheap these days. Personally, I feel that if it’s worth the effort to take the time to mod a light, it’s worth it to use a copper star.
I have an S2+ XPL Hi version with 8x AMC7135.
It is already heating up fast, I can imagine, that with the SST-40 driver almost the case starts to emit light also :smiley:
Some of my first LED projects used LEDs with the aluminum stars. I used a generic ‘hi power’ 5W led and ran it till it turned blue. Even at like 1.5A and 6.5V it was getting hot even with good heatsinking. Anything over 7W really needs a copper PCB to get the most out of the LED. My Nichia 319 Mtns dtp board is running 4A and isn’t even breaking a sweat. Now I have a few xhp70.2 and they are all driven hard but do great on copper boards.
