Convoy s21a biscotti - always ends up in mode group 1 + memory on
Hi,
I have problem with my convoy s21a sst 40 with biscotti firmware. No matter which mode group I set, after few days of usage it will randomly end up in mode group 1 with memory on…
I happends even if I do not take out the battery…
Any idea what could be the problem here?
I think this is quite a common problem. Seems to occur if you unscrew the head or tail (cutting power) when the light is on.
Looks like you are right. But for me it happens even if I do not unscrew light at all… Does that mean that there is bad connection somewhere between battery and led driver?
Not sure of the cause, I think it may have been a specific batch of drivers. This has been discussed previously on this forum, so maybe try the search function.
I will never buy another Convoy light due the these driver issues.
abgx1 did you buy your S21A directly from Simon at the official Convoy flashlight store
If so, have you tried to contact Simon about the issue? He has been very responsive and accommodating with any issues I’ve had over the years, which has been very minimal. His products are of very high quality.
But if purchased thru someone else, then you should contact the seller instead.
I have never run into these driver issues and have 11 convoy lights.
Its from simon, thanks, I will try to ask him…
