Hey everyone.
I’m pretty new to flashlight modding, the only thing I ever made myself was an S2+ with a single 519A.
I got some triple 519a boards from Kaidomain, and want to put them in an S21A and an M21B, and since I will be using them with a TIR lens, the pill will be further on the front than usual, and the battery might lose contact. Does anyone have any experience with modding these lights, and know where I can get a spacer?
Thanks!
Or actually, I think it would be better to get something like a spacer for the MCPCB (since the pill can’t be screwed all the way to the front).
What do people usually use for that? Copper?
Okay, so I’d need a copper spacer. Does anyone know where I could get a copper spacer, preferably in the EU? I can’t find a proper spacer anywhere, I saw a great thread about spacers from kiriba-ru, but they don’t seem to be available anymore
I have 2 answers to your query:
- Building a triple requires a spacer and drilling through the existing pill. The only commercial source for spacers I know of is MtnElectronics, but I don’t know what the international shipping policy is like.
- I think the 3x519A configuration will very soon become obsolete when the high CRI LHP531 arrives. With the usual single-5050 TIR, it will simultaneously out-flood and out-throw a triple 519A, and have better color rendering.
For the above reason, I couldn’t justify the effort of building a triple 519A. Triples are really just a solution to the historical problem of being unable to find LEDs that are simultaneously high-CRI and high-power. This problem no longer exists.
The simplest, easiest and cheapest way is to sand down clean some copper mcpcbs and stack them until you get the desired height.
You could also get a 25mm copper bar from Amazon and find a local machine shop with a lathe and have the spacers made.
Should look like this
Alright, thank you! I didn’t know a high CRI LHP531 was on the way. But I’m really stoked to try it once it becomes available!
I’m super excited for it too, and it should drop in 1-2 weeks!
I’m mostly excited because it should share the same phosphor as NV1010, which uses a different formulation from existing R9080 emitters and has extremely good performance in the blue-green region, which is traditionally the weakest point for blue-pumped LEDs like the 519A.
