So the Convoy S3 has a nice deep pill for stacked chip driver but has a somewhat shallow reflector where as the S2 has a shallow pill and a deep reflector correct? OK between the two I want to build a MTG2 16mm MCPCB and a 4.04Amp 17mm Qlite driver host I like the 22 mode driver because with the hot emitters i like to start them @ 2% or ML etc and work my way to the sun modes
has anyone built a MTG2 in the smaller EDC form hosts from convoy S series?
I will be using 2x 18350s 10a efest
This should be interesting. The S2 pill is 8mm coupled with a 18mm reflector for a total assembly of 26mm in a 122mm host. The S2+ pill is 13mm coupled with a shorter 11mm reflector for a total of 24mm in a slightly shorter 120mm host. So, the S2+ pill has more heatsinking potential.
I believe the S3 is also the shorter configuration like the S2+ with the larger pill. I have interchanged internals between the S2 and the S2+ (both 18350 and 18650 versions) with the springs easily taking up the slight 2mm difference. I really like the S2 series for the quality construction at a cheap price. My next project is going to be a S2+ triple now that my XP-G2 High CRI Aleph LE is completed. Fun Stuff!
If you're okay with a floody beam and filing a bit of the reflector I would say go for it :) I was lazy to file a reflector for my S2, so I ended up using an XHP50 instead :P
The driver is some funky one mode DD with a now magic smoke'd 8ohm color band resistor on it, but I'm pulling around 3A on 2*Efest Purple 18350 thanks to the magic smoke.
yes. so far so good. I put a bypass wire in from the top of the spring to the board though. I also built a S2+ pulling 8A with the mountain FET. triple XPG2, stock switch with the bypass wire. J)
there is always kapon tape, yes i keep waiting for the day when the centering ring insulators are available but I have found that a lot of thin hard plastics will hold up to the heat so DIY is always an option.
come on guys use your brain…be creative. you can use any kind of plastic like old credit cards or old ID card anything plastic doesn’t really matter even you can use paper
