【convoy】SFT70 3000K CRI95 available
There are two, the Thrunite TN42v2 with SBT90.2 and a large reflector (3x21D outshines it), and the Lumintop GT3 Pro sodacan (3x XHP70.2).
The GT94X might also count, but it is a much larger form factor.
As a charger? 4 cells will be connected in parallel. If you wanna charge 4 cells at the same time you have to make sure they are at the exact same voltage otherwise … kaboom!
Also with such a huge battery capacity I would want a power bank function out of it too.
After downloading the PDF explaining the XHP 70.3 with pictures I realized I had made a big mistake. Now I know what to look for. All of my other XHP70s have domes so I was very confused.
Which Aliexpress store did you buy it from?
Did you order it from “Convoy flashlight Store”?
yes this is Simon’s store.
Yes, I ordered from the Convoy flashlight Store. I’m guessing the ‘Message Seller’ feature only works from a computer and not a cell phone.
Question for @Simon_MAO:
Are there any plans for the SFT40 to be in a flashlight with the form factor of the L6 or L7?
Thank you.
If you use the Android App it works great however if you use a mobile web browser you are correct, it doesn’t work.
Be sure to include your Order# when you message them.
Simon will make it right.
Hi, does anybody know if S2+ 18350 tube is suitable to H1 headlamp?
Or a 46110 light.
I have both, I can check in a few hours but I don’t think so.
I agree. The S2+ tailcap fits on an H2 but the head threads are different. I’m guessing it might be the same for H1.
I’ve never used the AE app and have successfully messaged back & forth with Simon there several times…
I do find it works way better when I have my browser set to Desktop Mode, though.
Which Web Browser do you use?
Just the Chrome on my Android…
Hail to the “G” Overlords.
I’m using Chrome on my Samsung S20FE and i was unable to message Simon.
Thanks for the replies.
I was hoping for everything had migrated to the same threads, when they became square.
@YBF650 I appreciate you trying it for me.
I was pretty sure before but I am certain now, it does not fit. The tailcaps are similar enough, but the H1 head threads are larger diameter and much finer pitch than the S2+ head threads. Sadly it won’t work.
Well, what a pity they don’t match.
Researching a bit, I’ve found short tube for H1 was planned.
@Simon_Mao, is it on development at the moment?
What were those sale prices I saw earlier? Did I miss a convoy flashlight store sale?
